Duet dryer was giving an F01 code, but also working occasionally. I removed the control board and resoldered the burnt point and reinstalled. The dryer now gets the clicking sound, goes into "sensing" mode but doesn't work. If you move the dial to different cycles and push Start/Stop button, every now and again it starts up and the drum turns like normal. Then it will stop again after a minute or so, or sometimes run for 30 minutes, but we are constantly babysitting the load. I am thinking either the belt switch or fuse but don't want to wait another day to order parts. Any ideas?
