My dryer won't heat. I pulled the inspection plate off & could not see any sign of dryer trying to start, no flicker or flame. Also, timer sounds like it is running, but stays on the same time (eg:60 min.) Where should I start to get this thing running again? Thanks, in advance, wartrue
