Dryer works for a few minutes then stops drying. When it does a light in the display makes clockwise circles in the display. The back of the drum is so hot you can't touch it. There is no blockage as it still won't work with the vent disconnected. Both the high limit thermostat and the thermal limiter have continuity at room temp. The control board has been replaced. I'm stumped.
