Discuss
Alternate timer for Maytag Atlantis dryer
 in
Dryer Repair
I am looking at buying the above model dryer with s/n 195168600L that has a bad timer. ON looking for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Alternate timer for Maytag Atlantis dryer
  #1 (permalink)
Old 07-21-2015, 03:37 PM
Senior Member
thorning is on a distinguished road
Default Alternate timer for Maytag Atlantis dryer
Model Number: MDE6400AYW   Brand: Maytag   Age: More than 10 years
I am looking at buying the above model dryer with s/n 195168600L that has a bad timer. ON looking for the replacement part it appears this timer is very expensive. I have quite a few older usable timers from typical Maytag dryers such as model DE410 or DE412 and wondered if anyone has ever tried to make one of these work in place of the more expensive type. I am sure the wiring for the plug is different on the Atlantis but timers are essentially the same type of device. Any comments are welcomed.
Related Models
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
  #2 (permalink)
Old 07-22-2015, 10:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/pa...del=MDE6400AYW
Timers are machine specific so this would be a lot of effort
You also a wiring diagram for the older timer/unit.
Then you have to sit down and figure out if the two are even a close match.
You would also need the old plug with some wire attached so you can splice the wires in.
Could be a lot of work for nothing.
__________________
  #3 (permalink)
Old 07-22-2015, 11:09 AM
Senior Member
Default
It is sounding like a lot more work than it is worth. Guess I will have to bite the bullet after I pick it up and get a new or maybe a working used timer of that type specified for the Atlantis. Kind of a interesting problem since I have several good working timers from older Maytags.
  #4 (permalink)
Old 01-07-2018, 11:59 AM
Senior Member
Default
I recently was given another Maytag Atlantis electric dryer with model number MDE6400AYQ and s/n 19461681CR. It is in excellent condition in terms of appearance and very clean but It will not start or heat. I have checked every item that would normally be a possible source of the problem such as the thermal fuse (2), thermostats, door switch, heating element, and all the wiring connections. These items were all checked 3 times and no problem was found. The only item left was the timer which in my opinion is not as good as the old design timers plus a replacement of the original is very expensive. I have several older design timers which are typically Model 460-G and are in good working condition. The problem is that the original timer uses a 9 pin connector plug and the old design timers use individual connectors . Also the original timer is very loud when it runs as compared to the older design designs.. I am now trying to figure out how to make the connections to make the old design work on this Atlantis dryer. Any help would be appreciated.
  #5 (permalink)
Old 01-11-2018, 03:36 AM
Senior Expert
APP Volunteer
Default
Sorry for taking so long in getting back to you but I am no longer active on this forum.
Your best bet would be to try and find a used timer.
Trying to modify the unit to use a different timer will require you to have the wiring info on both units and may be a big pain it the you know what.
Alos even if you get the other timer to work it is doubtful that the times/functions would be a match.
__________________
  #6 (permalink)
Old 01-11-2018, 03:45 AM
Senior Member
Default
Thanks.
I have actually taken this "sealed" timer assembly apart and found the problem. It was easy to fix. My situation now is that when I was able to get it apart a couple of plastic levers fell out and I cant figure out how to get it back together properly. If you have any recommendations for a timer repair shop it would be greatly appreciated.
  #7 (permalink)
Old 01-11-2018, 11:10 AM
Senior Expert
APP Volunteer
Default
Sorry but I have never used a mechanical timer repair shop.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis new timer not working blewis123456 Dryer Repair 6 02-27-2015 08:24 PM
Maytag Atlantis Dryer timer which one? Stevenerd Dryer Repair 1 10-22-2014 02:26 AM
Maytag Atlantis timer problem alpo Washer Repair 1 11-02-2009 09:02 AM
Maytag Atlantis Dishwasher timer won't run whytfang Dishwasher Repair 2 03-29-2009 05:32 AM
timer, does not advance on maytag atlantis ippy Dryer Repair 1 03-22-2009 05:55 PM
