I have a wed9600tw0 dryer, and the last few weeks during the cycle a beeping will happen that will last maybe a minute and then stop.
This could happen a few times during the cycle Steps I have taken so far: :cleaned out dryer vent run :went in to diag mode and saw a code F25 :replaced the thermistor - which most F25 codes show to be the issue :"reset" in diag mode : Have run 2 cycles so far, F25 still appears as does occasional beeping
The cycles still seem to work ok, dryer is warm, and clothes get dry.
If while in diag mode I hit start, I see a "-:F2" appear .. not sure what that means, just another data point.
appreciate any assistance
