Dryer would sporadically heat, wouldn't more than would. I took it apart to check for continuity and lint build up. Everything seemed to check out except the vent so I replaced it and cleaned out the exit, all seemed ok for a few loads of laundry and then it stopped heating again. I checked for errors and found "e5b" so I decided to replace the heating element, thermistor, hi-temp thermostat and thermal limiter. Fired it up today and it worked, I thought all was well. An hour later my wife comes in and says it isn't heating.
What's the next step? I'm feeling a little Office Space-y at the moment. Thanks in advance!
