A model number may be helpful
Find your model number - AppliancePartsPros.comAlso did you replace the thermal fuse or the thermal cutoff.
The fuse kills power to the unit/motor.
The cutoff kills power to the heating coil.
Have you checked the power?
I would do that before going any further.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
