Discuss
Gas dryer short cycling
 in
Dryer Repair
Hello, My dryer heats for about two minute then the burner shut off stays off for about two minute the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer short cycling
  #1 (permalink)
Old 07-01-2015, 04:27 AM
Junior Member
cjonesc is on a distinguished road
Default Gas dryer short cycling
Model Number: SDG515Daww   Brand: Maytag   Age: More than 10 years
Hello,
My dryer heats for about two minute then the burner shut off stays off for about two minute the back on taking long time to dry.The dryer is free of lent ,filter clean,good air flow.The gas valve coil test good. I order a cycling thermostat i go a five terminal t-stat part#37001136 the stat that is on my old dryer is a four terminal. Where can i get a four terminal thermostat for this model? I am told the cycling stat for this model is obsolete How do i wire the five terminal to the dryer?
Thanks,
Cleveland
Related Models
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
Amana SDI22W-AG REF - SXS/I&W
Amana SDI22W-C REF - SXS/I&W
Amana SDI22W-L REF - SXS/I&W
Amana SDI25A REF - SXS/I&W
Amana SDI25A-A REF - SXS/I&W
Amana SDI25A-AG REF - SXS/I&W
Amana SDI25A-C REF - SXS/I&W
Amana SDI25B REF - SXS/I&W
Amana SDI25B-A REF - SXS/I&W
Amana SDI25B-C REF - SXS/I&W
  #2 (permalink)
Old 07-01-2015, 06:45 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Terminal 2 of the 5 terminal thermostat is not used on your dryer. Provide a photo of your existing thermostat. You may have faulty gas valve coils even though they test ok.
Eric
  #3 (permalink)
Old 07-01-2015, 07:49 AM
Junior Member
Default
Thanks for the information on the cycling thermostat.As for the gas valve coil i replaced the coil.Will the moisture sensor cause the burner to short cycle also?
Thanks,
Cleveland
  #4 (permalink)
Old 07-01-2015, 08:08 AM
Expert
APP Volunteer
Default
No, the only thing the moisture control does is control the timer motor during auto dry cycle. You replaced both gas valve coils? Did you use genuine factory service replacement coils? These coils are a very common failure item and there are lots of junk coils on the market.
Eric
  #5 (permalink)
Old 07-01-2015, 09:39 AM
Junior Member
Default
Thanks again for the information on the moisture sensor . For the gas valve i replaced both gas valve coil with genuine factory replacement coils.Later on during the week i will replace the cycling thermostat.
Thanks for your help
Cleveland
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire S/S not cooling, short cycling Moparrob Refrigerator & Freezer Repair 4 10-24-2014 01:32 AM
Compressor Short Cycling gutliaed Refrigerator & Freezer Repair 1 04-19-2014 03:48 AM
KitchenAid refrigerator clicking noise and fan short cycling jp65 Refrigerator & Freezer Repair 3 05-17-2013 08:54 AM
GE Dryer is short cycling tmangelsen Dryer Repair 0 09-29-2009 10:05 AM
GE Dryer is short cycling tmangelsen Dryer Repair 0 09-28-2009 12:15 PM
