Discuss
Fan Belt Replacement
 in
Dryer Repair
Hi, recently this morning my drier began to make a loud tumbling noise and slowly receded into a high pitched
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Fan Belt Replacement
  #1 (permalink)
Old 08-15-2007, 08:23 AM
atneffect atneffect is offline
Junior Member
atneffect is on a distinguished road
Default Fan Belt Replacement
Model Number: LDG882   Brand: Maytag   Age: 5 - 10 years
Hi, recently this morning my drier began to make a loud tumbling noise and slowly receded into a high pitched squeaking noise and the drum completely stopped revolving. After removing the front of the door and looking around under the drum, I manually spun it and saw that one of the fan belts was hanging on by a thread, and that a Roller had no fan belt attached. I was unable to see if there was a fan belt under the drum that was hanging off of it or if it was completely broken, but I believe it's the fan belts. If so, how would I go about replacing these myself? I also was reminded that I forgot to pull the plug out when I was moving the front door back into position, and a wire that is connecting to the loading door (it looks like it connects to the safety button that allows you to start the drier) sparked, smoked for an instant and now looks burnt. Could I have burned that out just by that one incident?
Thanks if you can help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer belt replacement mamasue Dryer Repair 0 08-14-2007 10:00 AM
belt replacement roy Dryer Repair 0 08-11-2007 10:01 AM
Replacement of Dryer Belt kcbrandt11 Dryer Repair 0 08-02-2007 03:25 PM
belt replacement honeypotx5 Washer Repair 0 08-01-2007 07:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
