Discuss
not heating on all selections
 in
Dryer Repair
I have installed new parts in my dryer. 2 Heater coils, bearing kit, drive belt, insulators for the coil and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » not heating on all selections
  #1 (permalink)
Old 10-28-2009, 11:07 AM
Junior Member
wado66 is on a distinguished road
Default not heating on all selections
Model Number: dlb6850bdl   Brand: Hotpoint   Age: More than 10 years
I have installed new parts in my dryer. 2 Heater coils, bearing kit, drive belt, insulators for the coil and a high limit thermostat. The problem I have is, when my selector switch is set to "perm press medium" I have no heat. When on "cotton high" both coils are on. When I am on "knits/delicates low" one coils is on.
My thoughts on this may be incorrect, but I was thinking that on "high" heat both coils stay on all the time. On "low" heat one coil stays on all the time. And on "medium" heat (my problem setting) the heat is regulated by the 2 low limit thermostats on my dryer door. And I am suspecting that one or both are bad. Is this a possible solution? Or am I way off base? I am in no way a technician. Just a guy trying to save some money and do it myself. Thanks for any help / information you have.
Related Models
General Electric DLB6850BDL Electric dryer
General Electric DLB6850BEL Electric dryer
General Electric DLB6850TA Electric dryer
General Electric DLB6850TDL Electric dryer
General Electric DLB6850TM Washer
Amana DLD10E COMMERCIAL MICROWAVES
Amana DLD10M COMMERCIAL MICROWAVES
Amana DLD10SE COMMERCIAL MICROWAVES
 DLE0332W Dryer
 DLE0442G Dryer
 DLE0442W Dryer
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
  #2 (permalink)
Old 10-28-2009, 11:36 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You may have hooked them up wrong.
I saw your earlier post but could not find a wiring diagram so did not reply.
Hotpoint is GE, so finding info on the net is near impossible, GE likes to keep their techs busy.
Here is a good site with some GE info
http://www.applianceaid.com/ge-dryers.html
Check out Item 28 "Sample wiring diagrams" perhaps this will help you confirm that they are wired in correctly.
Older style GE has the switch closure chart for the different temp settings so you can tell what is on when.
__________________
  #3 (permalink)
Old 10-28-2009, 07:37 PM
Junior Member
Default
Thanks for your reply. The site you gave is a great site for me. I really like the pictures going with the instructions.
I did find my wiring diagrem under the upper switch panel. I checked and everything is wired correctly.
I am still suspecting the two low limit thermostats. (Or high drum outlet and low drum outlet) according to the diagram. They are a little less than $17 each. So I think I am going to try them, unless yall have any other suggestions. Thanks again.
*edit*... After looking more into the site you had, I checked my low level thermastats. Put the ohms meter to the high drum outlet thermostat. And my needle pegged to the right.
Checked the low drum outlet thermostat. And nothing the needle didnt move.
According to http://www.applianceaid.com/ge-dryers.html thats not good.
So, again thanks for the info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating coil or Heating element assembly jayclagg Dryer Repair 1 02-11-2010 08:26 AM
Heating element stopped heating JSP38G0T1BB Gravity Railroad Oven Repair (including Ranges and Cooktops) 1 06-23-2009 03:10 PM
Bottom heating element in oven not heating Bill Pitts Oven Repair (including Ranges and Cooktops) 1 03-07-2009 07:02 PM
Heating element not heating JBM Dishwasher Repair 5 11-28-2008 12:37 AM
Dishwasher has limited selections charpenn Dishwasher Repair 0 04-04-2008 11:03 AM
