Motor went out on my Whirlpool duet gas dryer. Before replacing I checked continuity on thermal fuse and starter switch and both are good. Took out motor... it would start but only spin with assistance. Ordered replacement motor and installed... now no power going to motor at all. Thermal fuse and door switch still good. The motor was replacement model... #279787. It replaced motor model #S58SVMZS-6934. Does the wiring need to be re-arranged?
HELP!! - My teenagers are revolting due to lack of clean underwear.
