Rank:: Member
Hey guys, I have a GE electric dryer that is probably a little over ten years old. It makes this horrible squeaking noise w/ every rotation. I was wondering if there is a grease fitting that needs attention or if anyone might know how to make it a squeakless laundry experience. Any knowledge would be appreciated.
Here are your parts Parts for GE DVL223EB1WW Dryer - AppliancePartsPros.comCould be a bunch of things so you will have to open the unit up to find the cause. The most common cuase in these units is a dried out or worn rear drum support bearing. If it needs re-lubing be sure to use a high temperature grease. Could also be the front drum support, belt idler wheel or motor bearings. This is agood time to also check other internal parts and give it a good cleaning. I would also check/clean the vent system. |
THIS FORUM IS DEAD!!!!!!! |
