I have a Maytag Atlantis gas dryer that won't heat anymore. The igniter comes on then the flames. That lasts for about a minute then the flame go out. Then the igniter comes on but no flame. I replaced the gas valve coils but didn't change a thing. I checked the thermal fuse, cycling thermostat, hi limit thermostat, and flame sensor with a digital multimeter and were reading fine. The sensor inside the drum which I guess detects when clothes are wet-damp-dry had no reading. Could this be the problem? If not where do I go from here?
