Discuss
Broken Dryer Door Lever
 in
Dryer Repair
The lever that turns the light on and off when you open and close the dryer door is broken (it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Broken Dryer Door Lever
  #1 (permalink)
Old 10-27-2009, 04:24 PM
Junior Member
deziaueto is on a distinguished road
Default Broken Dryer Door Lever
Model Number: LT7100XVW0   Brand: Whirlpool   Age: 5 - 10 years
The lever that turns the light on and off when you open and close the dryer door is broken (it is very loose compared to not being very loose before). If I 'jiggle it the light will go on and off intermittently. I think this is also the reason my dryer will not work when the "Start" button is pushed (probably thinks the door is 'open and does not allow the dryer to start).
Per this particular make and model (Whirlpool Space Saver, LT7100XVW0) how do I take it apart to get to the section of the dryer door area to reposition or replace that dryer door switch/lever?
Thank you.
Related Models
Whirlpool LT7100XVW0 Laundry Centers
Frigidaire LT800EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT800EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT800EXD6 Wwh(v3) / Tumble Action Washer
Frigidaire LT800EXF1 Wwh(v4) / Tumble Action Washer
Frigidaire LT800EXF4 Wwh(v5) / Tumble Action Washer
Frigidaire LT800EXF6 Wwh(v6) / Tumble Action Washer
Frigidaire LT800EXH1 Wwh(v7) / Tumble Action Washer
Frigidaire LT800EXH4 Wwh(v8) / Tumble Action Washer
Frigidaire LT800EXH6 Wwh(v9) / Tumble Action Washer
Frigidaire LT800EXV1 Wwh(v10) / Tumble Action Washer
Frigidaire LT800EXV4 Wwh(v11) / Tumble Action Washer
Frigidaire LT800EXV6 Wwh(v12) / Tumble Action Washer
Frigidaire LT800EXW1 Wwh(v13) / Tumble Action Washer
Frigidaire LT800EXW4 Wwh(v14) / Tumble Action Washer
Frigidaire LT800EXW6 Wwh(v15) / Tumble Action Washer
Frigidaire LT800JXD1 Wwh(v1) / Washer
Frigidaire LT800JXF1 Wwh(v2) / Washer
Frigidaire LT800JXH1 Wwh(v3) / Washer
Frigidaire LT800JXV1 Wwh(v4) / Washer
Frigidaire LT800JXW1 Wwh(v5) / Washer
Frigidaire LT800LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT800LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT800LXW1 Wwh(v1) / Tumble Action Washer
Amana LTA85AW WASHER- HORIZONTAL AXIS
Amana LTC85AW WASHER- HORIZONTAL AXIS
Whirlpool LTE5243BN0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ3 LAUNDRY CENTER
Whirlpool LTE5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT2 LAUNDRY SYSTEM
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
  #2 (permalink)
Old 10-28-2009, 11:49 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Here is your part
Part number: AP2912526
See if this manual fits your machine.
https://secured.whirlpool.com/Servic...6_4314124A.pdf
__________________
  #3 (permalink)
Old 10-28-2009, 12:35 PM
Junior Member
Default
My goodness, this is the most detailed manual I have ever read. Not only does it give you the basic unpacking and setting up instructions, it also shows how to open up the washer and dryer to get to the basic areas that may need servicing. I will also get the part you suggested.
Thank you oh so much, now I can sleep at night!
Last edited by deziaueto : 10-28-2009 at 12:37 PM. Reason: Misspelled words, incomplete sentences
  #4 (permalink)
Old 10-28-2009, 01:49 PM
Senior Expert
APP Volunteer
Default
Glad you got the info, let us know how it turns out.
__________________
  #5 (permalink)
Old 09-06-2017, 06:45 PM
Junior Member
ofquiet is on a distinguished road
Default lt7100xvw0 wash/dry combo switch broken
Hi, I also have a broken dryer door switch but in the washer/dryer combo version of lt7100xvw0. Can you point me to the correct replacement switch part and more importantly how to get to it? I have tried several times but can't find a good way to access it. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure ServicePlus Refrigerator & Freezer Repair 15 05-03-2015 04:59 PM
Ice Maker lever broken Randall Smith Refrigerator & Freezer Repair 0 09-17-2009 04:43 PM
door knackered,possible lever brake broken? hellohello Dishwasher Repair 0 03-26-2009 01:00 PM
Reconnect Kitchenaid Door handle/lever? Longjack Dishwasher Repair 1 07-17-2008 12:55 PM
Water/icemaker lever on door will not work boldpilot Refrigerator & Freezer Repair 3 07-24-2007 06:09 AM
