widowson2
#1 Posted : Friday, April 3, 2015 1:56:32 PM(UTC)
widowson2
Dryer runs but no heat. I checked for continuity at heater element, ect. everything checked good but thermal protector. I checked the blower its tight and clean as is the vent and all associated duct work. Vent flap on outside of house also free and clean. I ordered a thermal protector kit and installed the protector, and dryer worked fine for 3 loads then stopped heating again. Thermal protector is open again. I took heating element off and took it apart, everything looked good, does not look like its grounding to housing. I reassembled and checked continuity again both the element it self then one contact on element to housing checked good. I'm at a lose Please Help!
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
