mnunncliff
#1 Posted : Sunday, March 22, 2015 11:08:13 AM(UTC)
mnunncliff
the heating element glows brightly with door shut and switches off. We were getting some squeaking with heavy loads when we first started using it. Last night we got rattling noises in the back and the above heating element (we assume) problem. thanks to all.
#2 Posted : Monday, March 23, 2015 2:41:03 AM(UTC)
Parts for Frigidaire FEQ332ES0 Dryer - AppliancePartsPros.com
Here is a better copy of the wiring diagram.
http://manuals.frigidaire.com/p...f/Webster/134064000e.pdf
The first thing to fix is the element being on when it should not be on.
Note that if the element is not grounded then you will have to also replace the motor as the centrifugal switch on the motor should kill power to the elemet when the motor is not running.
As far as the ratting etc. you will have to open the unit up to find the cause.
Note that a common problem on these units is the rear drum support/bearing.
Below is a manual which may be helpful to you.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...e&id=80;t=1427107177
mnunncliff
#3 Posted : Monday, March 23, 2015 8:00:26 AM(UTC)
mnunncliff
thanks denman
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas Yesterday at 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
