Hi, I have a washer/dryer combo stack unit that I'm working on. I removed the back panel and the drum/belt...As I finished removing the drum and front control panel. I noticed a red wire with a black line pulled apart from a terminal or circuit. I'm trying to figure out where this wire leads to?? I coiled the wire up & took a photo...wire can be seen on the left. Thanks ~ Ray ray rameris attached the following image(s):
