Discuss
dryer dead - fixed
 in
Dryer Repair
Last week our Whirlpool Duet Sport dryer stopped -- it was dead, no power, no lights, no nothing. After looking
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer dead - fixed
  #1 (permalink)
Old 10-27-2009, 08:32 AM
Junior Member
jptex is on a distinguished road
Default dryer dead - fixed
Brand: Whirlpool   Age: 1 - 5 years
Last week our Whirlpool Duet Sport dryer stopped -- it was dead, no power, no lights, no nothing. After looking on this forum I figured it likely was the thermal fuse, but it was simpler. This might apply to any model, any brand, depending on how sensitive it is to the right voltage.
Before disassembling anything, I figured I had better check the outlet for the correct 240 volts -- 120 on each leg. I used a voltmeter instead of light. Sure enough one leg showed 120, but the other was 44. It was the same at the load side of the breaker, so I switched the breaker off and on a few times.
That fixed the problem. The dryer then had 120 on each side, and it powered up and has run fine since. My wife says it dries better. She was having to run some loads twice. I suppose the low voltage could account for that.
Thought it might be helpful if you encounter the same symptoms.
Ads By Google
  #2 (permalink)
Old 10-28-2009, 11:58 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Thanks for the information.
When we respond to electric dryer problems about the first thing we say to folks is to test the voltage on each side of the connection block. It is not usually the problem, but sometimes it is, and if so it save a lot of money and time for the home owner.
Sometimes I do not thing they take this advice seriously, so your post will be helpful!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer runs, won't heat. FIXED LA Daddy Dryer Repair 1 10-03-2009 03:59 AM
My Dryer is dead Rositafresita Dryer Repair 1 07-21-2009 08:52 AM
Dryer Dead? Csearls Dryer Repair 21 03-01-2009 08:28 AM
dead dryer dwtdan Dryer Repair 1 02-06-2009 04:25 PM
Dead Dryer mbro Dryer Repair 0 02-19-2008 06:41 AM
