I have a Kenmore Dryer that won't heat up. After a few min of running it will stop and all 5 lights on the non-digital display will flash rapidly until I hit cancel.
I purchased it in 2006. A few years ago I replaced the heating element as it crumbled apart. Then in Jan of 2013 I had to replace the Main Control Board. Each time it failed on me before I'm pretty sure I actually was able to get a code to tell me what was not functioning. This time I don't seem to be able to.
I've tested the thermal fuse and the high limit thermostat for continuity and they were okay. I then checked the heating element last for continuity and I got a reading of .01 and no lower on my digi multimeter. Would you consider this failing? I hate this dryer.
Thanks guys Bill
