raymondsross
#1 Posted : Sunday, January 11, 2015 3:20:34 PM(UTC)
raymondsross
Maytag Dryer modal MGD5700TQ0. The timer stopped advancing in both timed and sensor modes. Assumed it was the timer itself that was bad so I replaced it. The new timer also will not advance. The dryer will shut off if I open the door or manually turn the timer to Off but even the new timer will not advance on it's own.
What other issue could i have that will not allow the timer to advance?
fairbank56
#2 Posted : Sunday, January 11, 2015 5:25:20 PM(UTC)
fairbank56
Groups: Expert
Sounds like you got another bad timer. Try again.
Whirlpool 8566184 Timer - AppliancePartsPros.com
Eric
econobiker
#3 Posted : Monday, January 12, 2015 8:03:30 AM(UTC)
econobiker
My dryer's heating element grounded out and the dryer timer would not advance as the timer was energized by the grounded electricity from the heating coil. The timer had a humming sound in it when it was turned to any cycle point but the start button was not pushed yet.
raymondsross
#4 Posted : Monday, January 12, 2015 11:29:23 AM(UTC)
raymondsross
I don't hear any buzzing or humming from the timer.
The timer knob does feel different physically when turning it. When the timer (old one) worked, there was some resistance/clicking when turning it to a setting. Once it stopped working, that resistance/clicking was gone and the resistance/clicking is also not happening with the newly replaced timer.
fairbank56
#5 Posted : Monday, January 12, 2015 1:17:32 PM(UTC)
fairbank56
Groups: Expert
It's a gas dryer, doesn't have an electric heating element. If you have power to the drum drive motor, then you have power to the timer motor and it should advance.
Eric
