Discuss
Power Contacts Burnned and Melted On My Dryer
 in
Dryer Repair
I have a Whirlpool ler8648lw0 with a 3 point power connection on the back- Black, white, and red wires stem
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Power Contacts Burnned and Melted On My Dryer
  #1 (permalink)
Old 10-26-2009, 07:30 PM
Junior Member
babridges0205 is on a distinguished road
Default Power Contacts Burnned and Melted On My Dryer
Model Number: ler8648lw0   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool ler8648lw0 with a 3 point power connection on the back- Black, white, and red wires stem from the contact points on the back of the dryer. The black wire on the power cord burned straight through and the red is charred. What in the heck happened!? I would get a new cord, but I dont want it to happen again and possibly have a worse outcome. Thanks!
Related Models
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
Whirlpool LET7848AQ2 ELECTRIC DRYER
Whirlpool LET7848AW0 Residential Dryer
Whirlpool LET7848AZ1 ELECTRIC DRYER
Whirlpool LET7848AZ2 ELECTRIC DRYER
Whirlpool LET7848DQ0 ELECTRIC DRYER
Whirlpool LET7848DQ1 ELECTRIC DRYER
Whirlpool LET7848DZ0 ELECTRIC DRYER
Whirlpool LET7848DZ1 ELECTRIC DRYER
Whirlpool LET8858AN1 ELECTRIC DRYER
Whirlpool LET8858AN2 ELECTRIC DRYER
Whirlpool LET8858AQ0 ELECTRIC DRYER
Whirlpool LET8858AQ1 ELECTRIC DRYER
Whirlpool LET8858AQ2 ELECTRIC DRYER
Whirlpool LET8858AW0 Residential Dryer
Whirlpool LET8858AW1 ELECTRIC DRYER
Whirlpool LET8858AW2 ELECTRIC DRYER
Whirlpool LET8858AZ0 ELECTRIC DRYER
Whirlpool LET8858AZ1 ELECTRIC DRYER
Whirlpool LET8858AZ2 ELECTRIC DRYER
Whirlpool LET8858DQ0 ELECTRIC DRYER
Whirlpool LET8858DQ1 ELECTRIC DRYER
Whirlpool LET8858DZ0 ELECTRIC DRYER
Whirlpool LET8858DZ1 ELECTRIC DRYER
Amana LEU108 RANGE- S/C S/I DDRAFT GAS
Whirlpool LEV4434AW0 Residential Dryer
Whirlpool LEV4436AW0 Residential Dryer
Whirlpool LEV4624BG0 ELECTRIC DRYER
Whirlpool LEV4624BN0 ELECTRIC DRYER
Whirlpool LEV4624BW0 ELECTRIC DRYER
Whirlpool LEV4634JQ0 ELECTRIC DRYER
  #2 (permalink)
Old 10-27-2009, 02:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LER8648LW0 | AppliancePartsPros.com
This may have been a problem from day one. If the power cord was not installed correctly (a loose or poor connection) then as power travels across this, heat is generated. This makes the connection worse which generates more heat and so on and so on till the connection heats up so much that it fails.
I am assuming that the power cord that is on the unit is an approved cord and that it is properly connected (4 wire or 3 wire hook up)
A couple things to check when installing a new line cord
1. Make sure the units wiring is good, if over heater (discolored and/or pitted). You may have to put on a new connector on it. Be sure to cut back the wire till you get to nice clean copper.
2. If using a 3 wire hook up check that the ground strap is OK.
3. It is a good idea to also replace the terminal block.
I now use connector goop on all my connections. Basically this is a conductive grease that was originally designed for aluminum wire connections to prevent corrosion. You do not want to use too much as it is conductive a very light coat is sufficient.
__________________
  #3 (permalink)
Old 10-27-2009, 04:07 PM
Junior Member
Are you saying that if it is properly connected to each individual connection point (black to black red to red and white to white) and it has a even a somewhat- not even noticable bad connection, that is could generated heat and melt that wires? Someone else I was talking to was saying that it is more than likley either a bad connection (like you said) or bad power cable and more than likely is nothing else wrong with the dryer since it happened at that particular location on the dryer. That sound right? Thanks alot for your reply because I am no electrician and am ignorant when it come to these things. Thanks again.
  #4 (permalink)
Old 10-27-2009, 05:17 PM
Senior Expert
APP Volunteer
Default
Yes. It could start out with a very small amount of heat and as I said get worse over time.
Yes I would say that is correct.
__________________
  #5 (permalink)
Old 10-27-2009, 05:52 PM
Junior Member
Default
I greatly appreciate your assistance denman. I'll give it a shot and see how it goes. Thanks Alot!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my dryer power cord melted away momthree Dryer Repair 1 04-21-2009 08:10 PM
Oven light has bad contacts jjhome Oven Repair (including Ranges and Cooktops) 0 02-05-2009 02:06 PM
Tissue Paper Contacts in Receptacle scott123 Oven Repair (including Ranges and Cooktops) 0 10-17-2007 04:13 AM
