Discuss
Squeaking noise coming from motor
 in
Dryer Repair
I have a Maytag gas dryer. Under power and when I turn the drum manually a loud squeaking noise comes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squeaking noise coming from motor
  #1 (permalink)
Old 10-26-2009, 07:50 PM
J.T. J.T. is offline
Junior Member
J.T. is on a distinguished road
Default Squeaking noise coming from motor
Brand: Maytag   Age: 1 - 5 years
I have a Maytag gas dryer. Under power and when I turn the drum manually a loud squeaking noise comes from the blower fan and motor. I removed the belt from the drum so I could turn the blower by hand and I still get the squeaking. Could the motor be bad or is it the blower fan?
  #2 (permalink)
Old 10-26-2009, 08:04 PM
Junior Member
Default
I have accessed the blower, removed both clamps. Part of the blower hub was broken into pieces. The blower will not slide off the shaft. Shouldn't it slide right off? It appears that hub has wedged itself onto the shaft.
  #3 (permalink)
Old 10-26-2009, 08:19 PM
Junior Member
Default
Update. I have been able to remove the blower. When I turn the motor shaft the squeaking appears to be coming from inside the motor. Please, anybody have any suggestions?
  #4 (permalink)
Old 10-27-2009, 04:11 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is a good link
http://www.applianceaid.com/dryers.html
Go to #10 and then #26 and then Check this out
Try to move the motor's armature if there is slop in the bearings the motor needs replacing.
Here is a thread with a suggestion from SublimeMasterJW
Amana Cries Out in Pain
If you try this use a 3in1 or sewing machine oil. Do not use WD40 ad it will not last very long.
__________________
  #5 (permalink)
Old 10-27-2009, 07:35 AM
Junior Member
Default
Thanks for the info Denman. If there is no "slop" in the drive shaft do you think oiling the shaft and bearings would be enough? I would hate to put it all back together and a couple of days later have the motor start doing the same thing. I'm not wondering if I should go ahead and bite the bullet and replace the motor.
  #6 (permalink)
Old 10-27-2009, 08:01 AM
Senior Expert
APP Volunteer
Default
Sorry I won't give advice on this as you can never tell how long it will last.
I would apply a drop or two directly on the shaft/bearing, then give it a spin if it is nice and quiet and spins freely I personally would just oil it but then I am cheap and retired so have the time to pull it apart again if things do not work out.
__________________
  #7 (permalink)
Old 10-27-2009, 08:02 PM
Junior Member
Default
Thank you for your sound advise. I was able to get the motor loose from the back of the blower housing and discovered the squeaking bearing. After a few doses of 3-in-1 oil, it's good as new. At least for now. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loud squeaking Noise Peter687 Dryer Repair 4 09-24-2009 01:01 PM
Squeaking noise when agitaites justjudy Washer Repair 1 09-20-2009 05:08 PM
squeaking noise tesslef Dryer Repair 1 07-29-2009 03:39 PM
Loud Squeaking Noise bdmcgal Dryer Repair 1 12-10-2008 08:13 PM
Loud squeaking noise during spin cycle thwillis99 Washer Repair 2 11-14-2007 10:27 PM
