| » Maytag electric dryer heat stays on |
Model Number: LDE8500ACW Brand: Maytag Age: 5 - 10 years
My Maytag electric dryer heat seems to be staying on even when the door is open. I notice it the first time when I came into the laundry room first thing in the morning and someone had taken a load out the night before and left the door open and it was hot inside. I turned the dial to the off position and the heat went off. It also does not seem to be cooling down in the automatic cycle. It use to be I would set it to less dry and then it would cool down and then finally stop after a few buzzes. Now it will buzz, but when I go to take the clothes out they are really hot. Any ideas what the problem is? I am afraid we are going to burn the house down.
Replacement parts for MAYTAG LDE8500ACW | AppliancePartsPros.com Sounds like you have a grounded element, the heating coil has sagged or broken and is touching the case. Usually you can see this when examining the heater assembly. You can also check it with a meter. Unplug the unite Remove both wires from the heater Measure the heater, usually around 10 ohms Then measure from each connector to the case/frame both should be infinite ohms.
__________________
Yea,
I have the same problem. Definitely a heating element sagging and grounding to the surround. I took mine apart and diagnosed it myself. The part #307178 is the assy and there is a broad range in cost across the internet. It comes without the heat deflector and a couple of electrical parts that you can use off of the old one. Most importantly, UNPLUG THIS DRYER NOW! It is a definite safety hazard at the moment. |
| Display Modes | |
| Maytag Electric Dryer Won't Heat | ayersl | Dryer Repair | 7 | 02-26-2010 03:09 PM |
| Maytag Performa Electric Dryer No Heat | linktlife | Dryer Repair | 7 | 11-03-2009 04:07 PM |
| Whirlpool Gas Dryer Runs, Start Heating then gas heat goes off - stays off... | drs | Dryer Repair | 15 | 09-02-2008 01:44 PM |
| Dryer running but heat only stays on for short while | hung380 | Dryer Repair | 1 | 04-30-2008 03:15 AM |
| whirlpool Dryer-heat stays on; now no start | jttgb24 | Dryer Repair | 9 | 02-04-2008 06:23 PM |
