lloyd329
#1 Posted : Thursday, January 1, 2015 10:12:26 AM(UTC)
lloyd329
Thermal Fuse, High Limit Thermostat, Cycling Thermostat all checked out good. Dryer was only coming on in the auto mode and not heating. Then the breaker kicked and it would not come on at all. I replaced the Timer and Heating element. Came on and heated on the auto mode BUT only hummed when on timed mode. Then when on Auto mode I moved the timer to the OFF position. Breaker kicked again. Now it only hums under both modes. I hope I did not burn out the timer I just installed. Please advise what to do next.
lloyd329
#2 Posted : Thursday, January 1, 2015 11:28:55 AM(UTC)
lloyd329
I forgot to mention that before replacing the Timer and heating element, the old timer did not count down on any setting. That was another reason why I decided to replace the Timer.
lloyd329
#3 Posted : Thursday, January 1, 2015 4:25:48 PM(UTC)
lloyd329
Update:
I removed the drum and belt to test the motor. The motor pulley spins fine. Only thing I don't get is that it will only engage when I hold the start button in. Once released, it stops spinning. Throws off heat too. Also, if I hold the button in too long the breaker kicks. Please remember all this is being done with the drum and belt removed. Any suggestions?
#4 Posted : Friday, January 2, 2015 1:07:51 AM(UTC)
Parts for Kenmore Dryer 11064742400 - AppliancePartsPros.com
You may have had two problems so I can only address your current symptoms.
I ma not sure what was going on with it starting just in auto.
It sounds like there may be a problem with a centrifugal switch on the motor.
The activate when the motor gets close to operating speed.
One of the switches has two functions.
It provides an alternate path for the start switch which keeps the unit running when you release the start switch.
It also disconnects the start winding which if left in circuit causes the motor to overheat and trip it's internal thermal protect.
The switches are not available as a separate item so the motor must be replaced.
File Attachment(s):
64742400.pdf (215kb) downloaded 7 time(s).
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
