Stash
#1 Posted : Tuesday, December 30, 2014 3:43:09 PM(UTC)
Stash
My Whirlpool Cabrio dryer seems to over heat and puts out high temps no matter what the temp setting....high , med , or low .
I've checked the whole vent system and the blower , as well as the inside of the cabinet and have found no problem .
Is there a temp thermostat or temp control which may have gone bad and needs replacing ?
thanks
#2 Posted : Wednesday, December 31, 2014 4:29:14 AM(UTC)
Parts for Whirlpool WED6200SW1 Dryer - AppliancePartsPros.com
Yes there is a thermistor that can be checked, see the tech sheet.
The first thing I would check for a grounded element.
Unplug the unit and both wires from the element.
Measure across the element, should be 8 to 12 ohms.
Then measure from each side if the element to it's cas, both should be infinite ohms.
If not the element is grounded and should be replaced.
File Attachment(s):
WED6200.pdf (417kb) downloaded 4 time(s).
Stash
#3 Posted : Thursday, January 1, 2015 8:49:59 AM(UTC)
Stash
thanks for your help and tech info , Denman .
Stash
Stash
#4 Posted : Thursday, January 1, 2015 8:52:09 AM(UTC)
Stash
thanks for your help and tech info , I'll check the heating element for grounding .
Stash
Stash
#5 Posted : Thursday, January 1, 2015 8:54:56 AM(UTC)
Stash
Stash
( this looks like more than 10 characters to me , but the website keeps kicking it back to me ! )
Stash
#6 Posted : Thursday, January 1, 2015 3:27:53 PM(UTC)
Stash
Stash
I'll check the heating element .
Stash
