DALE R
#1 Posted : Monday, October 26, 2009 4:11:25 PM(UTC)
DALE R
Dryer Doesn't Heat Up,
DALE R
#2 Posted : Monday, October 26, 2009 4:13:31 PM(UTC)
DALE R
Dryer Doesn't Heat Up, Have Continuity On Coil & Thermostat. Also Have 240 Power.
DALE R
#3 Posted : Monday, October 26, 2009 4:23:19 PM(UTC)
DALE R
Dryer Doesn't Heat Up, Runs Good, Followed All Of The Repair Instructions, Ran Continuity Tests On Everything, Coil Looks Good & Still No Heat, Help
SublimeMasterJW
#4 Posted : Monday, October 26, 2009 4:53:29 PM(UTC)
SublimeMasterJW
If you have power to the unit and all of the various safety's and element is checking out ok, then you need to check the timer. The large red wire going into the timer(colors vary on dif mods) is the weakest point, it draws a tremendous amount of current from the heater element and is the most frequent failure point in the timer. Remove the large red wire on the terminal marked RH on the timer. Slowly turn the timer and check for continuity between the RH terminal and every terminal on the timer. If you cannot get a continuity reading at any point in any cycle, then the contact inside the timer is burned up. Timer replacement will be nessesary. Here is a burnt contact:
UserPostedImage
Click on pic to enlarge
Sometimes you can file that contact down and go some more. This one looks fileable.
I have seen em burnt slap up nothing left to file down.
Dryer doesn't dry completely (Dryer Repair)
by Guest 10/16/2021 9:43:41 AM(UTC)
Dryer doesn’t work on all cycles (Dryer Repair)
by dk123 4/6/2020 7:45:37 PM(UTC)
Dryer Doesn't Stop despite buzzer (replaced timer) (Dryer Repair)
by safashton 9/29/2019 3:07:46 PM(UTC)
Samsung Dryer doesn't tumble, no sounds at all (Dryer Repair)
by TeqToo 10/10/2017 3:19:17 PM(UTC)
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
Gas dryer doesnt get hot (Dryer Repair)
by DPForumDog 1/29/2017 8:52:22 PM(UTC)
dryer doesn't stay hot (Dryer Repair)
by tater9.75 10/24/2016 12:40:59 PM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Hotpoint dryer doesn't stay running (Dryer Repair)
by mvask193 7/16/2015 5:47:39 PM(UTC)
Dryer doesn't work on cool down (no heat) cycles (Dryer Repair)
by Jltapalmieri 4/10/2015 8:44:03 AM(UTC)
Whirlpool dryer doesn't shut off in auto mode (Dryer Repair)
by mikepukmel 3/9/2015 7:13:28 PM(UTC)
dryer doesn't produce enough heat (Dryer Repair)
by mraskin 1/17/2014 1:22:16 AM(UTC)
Maytag Dryer doesn't always heat (Dryer Repair)
by Sbrock1165 1/5/2014 7:34:32 PM(UTC)
GE Dryer doesn't automatically stop (Dryer Repair)
by ericfeiss 1/4/2014 7:38:26 AM(UTC)
Dryer doesnt heat up ALL the time (Dryer Repair)
by Hattrix 12/14/2013 5:41:08 PM(UTC)
