I have a GE dryer that powers up but when you push the start button it makes a click sound that appears to be coming from the control board but it does not start--it clicks again when you press state/pause or open the door. I have replaced the inlet control thermis (came apart while trying to remove the wires) and checked the two safety thermostats on the back and both seem to be fine. The door switch appears to be working because the clicking sound that occurs when you press the state button does not happen when the door is open. The belt seems fine and there is no humming sound coming from the motor.
Does anyone have any ideas as to what else I should be checking and how to do so? Any help would be greatly appreciated. Thank you!
