My Samsung dryer is 2 years old. During operation, the bottom door hinge arcs intermittently (probably every 30 seconds or so). This seems to be happening in all settings (sensor, no sensor, high heat, low heat). I know there is no wiring in the door (I took it apart), so I'm confused as to what might be causing this. What could be the culprit? I posted a video of it to youtube: https://www.youtube.com/watch?v=5BfCyQWbqMM&list=UUdYVMCRHQk4j8vpgoFcN2SQ
