Help! I have a cabrio steam dryer that had power, but stopped running. after some investigating found the thermal fuse needed replacing. Accomplished that and also cleaned lint from inside the cabinet, lint housing, etc. Vent is clear. Thought problem was solved, but it still is running too hot and clothes are extremely wrinkled. Should i have changed thermister also?? After doing several loads of laundry today, its back to not running. I depressed and held the wrinkle free button looking for some code, thats when it stopped working again. Have gotten AF air flow error in past, but cant find any restrictions. Thanks
