Discuss
dryer switch
 in
Dryer Repair
When I push the start button on the dryer, it turns on, but then kicks off immediately. I've tried
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer switch
  #1 (permalink)
Old 02-18-2008, 11:00 AM
valarieja valarieja is offline
Junior Member
valarieja is on a distinguished road
Default dryer switch
Model Number: dea500-cow   Brand: Kelvinator   Age: 5 - 10 years
When I push the start button on the dryer, it turns on, but then kicks off immediately. I've tried to restart it using all the different cycle options.
I also tried to shut the breaker off for the dryer, the turned it back on, went back.... pushed the button on the dryer, same thing .. switches on, then right off again.
Not sure what else to check or to do?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 07:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Did it stay "on" while you kept the "start" button depressed?
Did it make any noise at start up?
If the first answer is "No" and the second is "Yes" then most likely the motor is gone bad. Unfortunately the motor for this dryer is no longer available.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-19-2008, 06:37 AM
Junior Member
Default
The dryer only stays on for a split second and no it doesn't seem to make any noises other than normal startup stuff... just kicks right off.
  #4 (permalink)
Old 02-19-2008, 09:17 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I still believe the problem caused by the bad motor which is no longer available.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace Maytag Dryer timer switch? tlhjax Dryer Repair 1 03-11-2008 06:12 PM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
Infinite switch and fan switch johnro24 Oven Repair (including Ranges and Cooktops) 0 12-05-2007 10:01 PM
lid switch bellport Washer Repair 0 11-07-2007 08:53 PM
How do I Get to My Dryer Door Switch aburwick Dryer Repair 1 08-08-2007 05:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
