We bought this dryer new in 2004, and it worked wonderfully. After we owned it for about 7 years, the dryer started to make a harsh grating grinding noise. We immediately stopped it. When I opened the back of the dryer, it was clear the motor retainer clip had slipped off the circular end of the motor such that the motor axle could no longer be turned easily which caused the grinding noise. I remounted the axle and retaining spring and the dryer worked correctly until about 2 weeks later it happened again. I repaired it again. A month later the same thing. After about 10 iterations of this, I ordered a new retainer clip thinking that the clip had lost its retaining ability. After 3 months, the retainer clip slipped and I repaired it again. I thought Bosch made better stuff than this. Got any thoughts on this, short of buying a new dryer? [HTML][/HTML] sdonohue attached the following image(s):
