AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Question about replacement high limit thermostat part
Dryer has no heat. Tested thermal fuse and heating element and they were both okay. High limit thermostat crumbled when I pulled off wires so I definitely need to replace it now; however, new part (279052) has three connectors and old part only had two. I've watched videos for fixing new dryers and there is a purple wire but my dryer is old and there is no purple wire. Do I have the correct replacement part? Do I just ignore this third connection? Thank you!
Dryer Repair
