Parts for Whirlpool WED5500XW0 Dryer - AppliancePartsPros.comDo you have the tech sheet?
Have you checked the power to the unit?
If not start there.
The lights control board etc run off od 120 volts but the heater requires the full 240 volts (L1 to L2)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Blue"]Be careful as 240 volts is lethal !!![/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
