I have replaced the coils, ignitor, heat sensor, and the high, low, & cycling thermostat and now it works on low heat only. Also sometimes i have to play with the timer because i dont hear it come on or flame up. So after playing with the timer i hear it click and then ignite and flame up. Is the timer the problem and should be replaced or is it something else?
