DPSscott
#1 Posted : Sunday, November 9, 2014 5:03:43 AM(UTC)
DPSscott
my dryer timer will rotate and count down up to the point of tripping the machine to stop. if I bang on the top it then will trip. my wife said she put a load in for 30 min checked on it and timer was "almost at zero" rechecked after 90 min it still was running so she stopped the load all was bone dry.
is it the timer or the resistor or both?
thanks for any help
fairbank56
#2 Posted : Sunday, November 9, 2014 5:35:10 AM(UTC)
fairbank56
Groups: Expert
If the timer advances normally during auto dry cycle, then the resistor is ok and you would need to replace the timer.
http://www.appliancepartspros.c...er-695760-ap2997376.html
Eric
DPSscott
#3 Posted : Sunday, November 9, 2014 6:40:01 AM(UTC)
DPSscott
Whirlpool 695760 Timer - AppliancePartsPros.com
Eric
when you say auto dry do you mean the one where I choose more/less dry . we never use that cycle we always use time dry.
I pulled the resistor it ohms at 4650 is that what it should be?
fairbank56
#4 Posted : Sunday, November 9, 2014 6:47:09 AM(UTC)
fairbank56
Groups: Expert
Yes, the more/less dry area of the timer is auto dry and yes, that is a normal reading on the resistor.
Eric
DPSscott
#5 Posted : Sunday, November 9, 2014 6:51:34 AM(UTC)
DPSscott
thanks for the advise
I will test on that cycle
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
