TomK12
#1 Posted : Friday, October 3, 2014 8:06:11 AM(UTC)
TomK12
Heating element is on as soon as dryer is connected to power.
When I setup the timer for any program and I press start the drum is not moving.
any suggestions?
fairbank56
#2 Posted : Friday, October 3, 2014 11:04:59 AM(UTC)
fairbank56
Groups: Expert
Check the motor switch. Unplug dryer, open control panel and disconnect purple (may be blue) wire from timer PU/BU terminal. Check resistance between the terminal on that wire to both of the flat blades on the power plug. If you read a low resistance on one of the blades to the wire, the motor is faulty.
Eric
TomK12
#3 Posted : Monday, October 6, 2014 4:58:51 AM(UTC)
TomK12
Thank you for your suggestion but this is what i found
Reason -> Heat element welded to housing.
Reason -> The thermal fuse was bad. I connected two wires without thermal fuse and drum was moving.
I order new parts (heating element and thermal fuse) form ********. I will post the update as soon as I replace the bad parts.
fairbank56
#4 Posted : Monday, October 6, 2014 11:54:27 AM(UTC)
fairbank56
Groups: Expert
If timer is in OFF position, the heater should not come on even if it is grounded. I had assumed this was the case. If it is, then you have a faulty motor switch or timer in addition to the grounded element.
Eric
Heating element will not turn off (Oven Repair (including Ranges and Cooktops))
by lcimino1967 4/13/2013 5:14:01 AM(UTC)
