wattsy
#1 Posted : Wednesday, October 1, 2014 2:58:28 PM(UTC)
wattsy
Maytag 2000 series electric dryer. I'm getting no power at all. Nothing on the panel and no light inside the drum. Tested the outlet with multimeter. All good. Tested the thermal fuse, door switch, thermostat, element ... all showed continuity except the thermistor. It did show 13.5 in the 200 (i think) ohms setting.
Is it the control panel and how can I test it?
#2 Posted : Thursday, October 2, 2014 6:02:47 AM(UTC)
Parts for Maytag YMEDE250XL0 Dryer - AppliancePartsPros.com
Do you have the tech sheet?
The drum light does not go through the control board so it may be a power problem.
Neutral (white) to L1 (black) is the side of the line that powers the board and the drum light.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the wall receptacle.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Your thermistor reading does look low but it may be that you were on a different meter scale.
wattsy
#3 Posted : Friday, October 3, 2014 8:04:58 AM(UTC)
wattsy
Turns out there's a sub panel in the house that was never labelled proper. It is now and that's where the 1 fuse was (old screw in style) that was blown. Got a 110 shock while I was working on something I thought was shut down at the wrong panel. Followed all the fuses and found the proper one and shut down the old 220 that was still open. Grateful it wasn't 220 at the time I got the zap. So thanks for steering me in the right direction. I'm still alive and well :)
#4 Posted : Saturday, October 4, 2014 12:46:02 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Seems you got a win/win.
You are alive and as a bonus have a working drier.
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
Dishwasher stopped mid-cycle, no power (Dishwasher Repair)
by cdnfamilyguy 10/25/2021 4:37:07 AM(UTC)
Frigidaire - Ice Dispenser - No Power (Refrigerator & Freezer Repair)
by moleson 9/16/2021 1:48:52 PM(UTC)
