stevechar
#1 Posted : Sunday, September 21, 2014 8:33:08 AM(UTC)
stevechar
Not sure if I should replace the cycling thermostat or moisture sensor board. The dryer heats and timer control advances only in time mode. Auto cycles heat but do not advance. Should I replace the cycling thermostat or moisture control board? Will either of the items help remedy the auto advance cycle? There is continuity on the old cycling thermostat but I am not sure quite how they function. Can it have continuity when cool and not function? Can you give me advice on how to proceed?
fairbank56
#2 Posted : Sunday, September 21, 2014 9:04:32 AM(UTC)
fairbank56
Groups: Expert
Why are you starting a new thread??? Did you clean the sensor bars as I advised in your original thread?
http://forum.appliancepartspros...ry-will-not-advance.html
Eric
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
Timer will not advance (Dryer Repair)
by Mechris 10/25/2016 6:30:42 AM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Timer will not advance after lightning strike (Dryer Repair)
by jwahl16 9/3/2014 2:23:07 PM(UTC)
New timer will not advance (Washer Repair)
by meganbella 4/5/2013 7:02:18 AM(UTC)
GE washer timer will not advance. (Washer Repair)
by Chumlord 6/29/2010 2:52:09 PM(UTC)
Dryer timer will not advance (Dryer Repair)
by Brian7780 6/19/2010 7:23:44 AM(UTC)
Timer will not advance in cool down part of cycle (Dryer Repair)
by Blake1111 3/30/2010 2:00:14 PM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Timer will not advance in Auto Dry (Dryer Repair)
by KSherer 6/2/2009 6:17:52 PM(UTC)
Maytag timer will not advance (Washer Repair)
by Robinscs 2/18/2009 2:40:20 PM(UTC)
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 1/15/2009 9:42:24 AM(UTC)
Timer will not advance (Dishwasher Repair)
by geraki 12/11/2008 10:08:47 AM(UTC)
