Discuss
lower Door Water leakage problem
 in
Dryer Repair
This is a used Kenmore Ultra Wash Plus dishwaher we just installed. An older washer ,another make was removed from
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » lower Door Water leakage problem
  #1 (permalink)
Old 10-25-2009, 08:01 AM
Junior Member
roncorkum is on a distinguished road
Default lower Door Water leakage problem
Model Number: 110753793   Brand: Kenmore   Age: More than 10 years
An older washer ,another make was removed from this same location and worked fine here for years.
With this Kenmore unit water leaks out the bottom of the door when the washer is cycling through a wash.
I tried leveling it up in the front with some shingles to prevent it from flowing over the bottom tray out on to the floor.The tray seems to be full of water when I stop the washer and look inside.This does not seem to help ,and may even make the problem worse.
Is there a water seal between the door and tray?
It looks like the door is designed to lock down over the lip of the tray when it closes.
Any comments to help here is greatly appreciated
Thanks Ron
Related Models
Kenmore 11075601 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075822400 RESIDENTIAL DRYER
Kenmore 11075922400 RESIDENTIAL DRYER
Kenmore 11075922401 RESIDENTIAL DRYER
Kenmore 11075924400 RESIDENTIAL DRYER
Kenmore 11075924401 RESIDENTIAL DRYER
Kenmore 11075926400 RESIDENTIAL DRYER
Kenmore 11075926401 RESIDENTIAL DRYER
Kenmore 11075942400 RESIDENTIAL DRYER
Kenmore 11075942401 RESIDENTIAL DRYER
Kenmore 11075944400 RESIDENTIAL DRYER
Kenmore 11075944401 RESIDENTIAL DRYER
Kenmore 11075946400 RESIDENTIAL DRYER
Kenmore 11075946401 RESIDENTIAL DRYER
Kenmore 11075962400 RESIDENTIAL DRYER
Kenmore 11075962401 RESIDENTIAL DRYER
Kenmore 11075964400 RESIDENTIAL DRYER
Kenmore 11075964401 RESIDENTIAL DRYER
Kenmore 11075966400 RESIDENTIAL DRYER
Kenmore 11075966401 RESIDENTIAL DRYER
Kenmore 11076002010 GAS DRYER
Kenmore 11076002011 GAS DRYER
Kenmore 11076051690 COMMERCIAL GAS DRYER
Kenmore 11076051691 COMMERCIAL GAS DRYER
Kenmore 11076058690 COMMERCIAL GAS DRYER
Kenmore 11076058691 COMMERCIAL GAS DRYER
Kenmore 11076065 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11076071690 COMMERICAL GAS DRYER
Kenmore 11076071691 COMMERCIAL GAS DRYER
Kenmore 11076112500 DRYER
Kenmore 11076112501 RESIDENTIAL DRYER
Kenmore 11076152500 RESIDENTIAL DRYER
Kenmore 11076401100 KENMORE ELECTRIC DRYER
Kenmore 11076401400 KENMORE ELECTRIC DRYER
Kenmore 11076401600 KENMORE ELECTRIC DRYER
Kenmore 11076402100 KENMORE ELECTRIC DRYER
Kenmore 11076402110 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402400 KENMORE ELECTRIC DRYER
Kenmore 11076402410 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402600 KENMORE ELECTRIC DRYER
Kenmore 11076402610 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076403100 KENMORE ELECTRIC DRYER
Kenmore 11076403400 KENMORE ELECTRIC DRYER
Kenmore 11076403600 KENMORE ELECTRIC DRYER
Kenmore 11076404100 KENMORE ELECTRIC DRYER
Kenmore 11076404110 SEARS ELECTRIC DRYER
Kenmore 11076405100 KENMORE ELECTRIC DRYER
Kenmore 11076405400 KENMORE ELECTRIC DRYER
Kenmore 11076405600 KENMORE ELECTRIC DRYER
Kenmore 11076406100 KENMORE ELECTRIC DRYER
Kenmore 11076406110 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076406400 KENMORE ELECTRIC DRYER
Kenmore 11076406410 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076406600 KENMORE ELECTRIC DRYER
Kenmore 11076406610 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076407100 KENMORE ELECTRIC DRYER
Kenmore 11076407400 KENMORE ELECTRIC DRYER
Kenmore 11076407600 KENMORE ELECTRIC DRYER
Kenmore 11076408100 KENMORE ELECTRIC DRYER
Kenmore 11076408110 SEARS ELECTRIC DRYER
Kenmore 11076408120 ELECTRIC DRYER
Kenmore 11076408130 ELECTRIC DRYER
Kenmore 11076408140 ELECTRIC DRYER
Kenmore 11076408150 ELECTRIC DRYER
Kenmore 11076408160 ELECTRIC DRYER
Kenmore 11076408220 ELECTRIC DRYER
Kenmore 11076408230 ELECTRIC DRYER
Kenmore 11076408240 ELECTRIC DRYER
Kenmore 11076408250 ELECTRIC DRYER
Kenmore 11076408400 KENMORE ELECTRIC DRYER
Kenmore 11076408410 SEARS ELECTRIC DRYER
Kenmore 11076408420 ELECTRIC DRYER
Kenmore 11076408430 ELECTRIC DRYER
Kenmore 11076408440 ELECTRIC DRYER
Kenmore 11076408450 ELECTRIC DRYER
Kenmore 11076408600 KENMORE ELECTRIC DRYER
Kenmore 11076408610 SEARS ELECTRIC DRYER
Kenmore 11076408620 ELECTRIC DRYER
Kenmore 11076408630 ELECTRIC DRYER
Kenmore 11076408640 ELECTRIC DRYER
Kenmore 11076408650 ELECTRIC DRYER
Kenmore 11076408660 ELECTRIC DRYER
Kenmore 11076408800 KENMORE ELECTRIC DRYER
Kenmore 11076408810 SEARS ELECTRIC DRYER
Kenmore 11076408820 ELECTRIC DRYER
Kenmore 11076408830 ELECTRIC DRYER
Kenmore 11076408840 ELECTRIC DRYER
Kenmore 11076408850 ELECTRIC DRYER
Kenmore 11076408860 ELECTRIC DRYER
Kenmore 11076409100 ELECTRIC DRYER
Kenmore 11076409110 ELECTRIC DRYER
Kenmore 11076409120 ELECTRIC DRYER
Kenmore 11076409130 ELECTRIC DRYER
Kenmore 11076409140 ELECTRIC DRYER
Kenmore 11076409150 ELECTRIC DRYER
Kenmore 11076409210 ELECTRIC DRYER
Kenmore 11076409220 ELECTRIC DRYER
Kenmore 11076409230 ELECTRIC DRYER
Kenmore 11076409240 ELECTRIC DRYER
Kenmore 11076409410 ELECTRIC DRYER
Kenmore 11076409420 ELECTRIC DRYER
Kenmore 11076409430 ELECTRIC DRYER
Kenmore 11076409440 ELECTRIC DRYER
Kenmore 11076409610 ELECTRIC DRYER
Kenmore 11076409620 ELECTRIC DRYER
Kenmore 11076409630 ELECTRIC DRYER
Kenmore 11076409640 ELECTRIC DRYER
Kenmore 11076409650 ELECTRIC DRYER
Kenmore 11076409810 ELECTRIC DRYER
Kenmore 11076409820 ELECTRIC DRYER
Kenmore 11076409830 ELECTRIC DRYER
Kenmore 11076409840 ELECTRIC DRYER
Kenmore 11076409850 ELECTRIC DRYER
Kenmore 11076410100 KENMORE ELECTRIC DRYER
Kenmore 11076410110 KENMORE ELECTRIC DRYER
Kenmore 11076410120 KENMORE ELECTRIC DRYER
Kenmore 11076420100 KENMORE ELECTRIC DRYER
Kenmore 11076420110 KENMORE ELECTRIC DRYER
Kenmore 11076423100 ELECTRIC DRYER
Kenmore 11076423110 ELECTRIC DRYER
  #2 (permalink)
Old 10-25-2009, 08:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Your Model Number looks like it is short a couple digits.
I cannot find any info on it.
I can tell you it is made by Whirlpool re:110
Check to make sure the unit is emptying out all the water at the end of a cycle.
Sometimes poor draining will leave water in the tub, then when it fills it is actually overfilled and the float/ flood switch shuts off the water valve. It will not leak while just sitting there but the wash turbulence will cause some water to splash out.
Does the unit hav a nams re: jet Clean etc. maybee I can find info using that if all you have is the listred Model Number.
__________________
  #3 (permalink)
Old 10-25-2009, 08:34 AM
Junior Member
Default Dishwaher leakage problem.
Thank you for responding.I rechecked my information.The name on the door front is Kenmore and below it Ultra Wash Plus. The serial # 110753793 from manufacturing tag id inside the washer. The serial # is FE 5205100
Where do I look to find the drain and how can I make sure it is clear and removing the water properly.
Thanks Ron
  #4 (permalink)
Old 10-25-2009, 08:42 AM
Junior Member
Default Kenmore Ultra Wash Plus door leakage
Correction to My last post ( Model#) 110753793
Ron
  #5 (permalink)
Old 10-25-2009, 09:25 AM
Junior Member
Default Kenmore Ultra Wash Plus Dishwasher
Just to be clear!
My problem,I am having water leakage at the bottom of the dishwaher door.
Please note this is a Kenmore dishwasher and not to be confused with a clotheswasher.
Mode # 110753793
Seriel # FE5205100
Thanks Ron
  #6 (permalink)
Old 10-25-2009, 10:07 AM
Senior Expert
APP Volunteer
Default
I was referring to a dishwasher.
Sorry, cannot find any info on this unit.
I will try to find info using UtraWash
Here is a good site with dishwasher repair help
http://www.applianceaid.com/dishwash.html
__________________
  #7 (permalink)
Old 10-25-2009, 10:57 AM
Junior Member
Default Thank you,I believe our problem is now resolved!
Thank you Denman,
I checked the dishwadher drain further after you mentioned the drain may be a problem and found short pieces of label plastic caught in the entry areas to the sump which I cleaned out This clear plastic was not readily noticed at first from taking a look but prying with a metal envelope opener I found a number of pieces. I figure there was enough pieces to perhaps hamper 20% of the flow.We just ran a wash cycle after clearing it out without any leaks so with fingers crossed,I believe it is now fixed.
Thank you for steering me in the right direction to resolve this problem.
Ron
  #8 (permalink)
Old 11-05-2009, 08:53 AM
Junior Member
Default Kenmore ultra wash dishwasher
My drainage problem still exists,thought I had it. How do I take it apart to clear the pump area of any further debris?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer water leakage 225sylvia Refrigerator & Freezer Repair 0 01-20-2010 11:31 AM
water leakage jfbtsg Washer Repair 1 10-02-2009 08:16 PM
Kitchen Aid Refriegerator Water Leakage amit76 Refrigerator & Freezer Repair 2 08-18-2009 07:47 AM
water leaks from lower corners of door don batchelor Dishwasher Repair 0 08-02-2009 01:13 PM
Lower door hinge assembly problem tulanh Refrigerator & Freezer Repair 3 06-12-2008 11:35 PM
