lkast
#1 Posted : Monday, August 25, 2014 5:52:55 AM(UTC)
lkast
My timer on my dryer stays in one spot and dryer does not heat up. I put it on a different setting and it will move towards off but doesn't shut off and still doesn't heat up. What can it be? How can I possible repair it myself. In my area it is so expensive for a repair call nonetheless the repairs. Thanks
#2 Posted : Monday, August 25, 2014 8:01:19 AM(UTC)
Unplug the unit.
Check the heating element with a meter.
They are usually around 8 to 12 ohms.
Most unit timers get power through the heating coil in any auto cycle type.
In timed dry the timer would get power directly through a set of timer contacts.
fairbank56
#3 Posted : Monday, August 25, 2014 9:12:42 AM(UTC)
fairbank56
Groups: Expert
What is the model number? If it is a gas dryer, it doesn't have a heating element.
Eric
lkast
#4 Posted : Tuesday, August 26, 2014 5:00:11 AM(UTC)
lkast
Originally Posted by: denman Go to Quoted Post
Unplug the unit.
Its an electric dryer. Thank you
fairbank56
#5 Posted : Tuesday, August 26, 2014 5:31:39 AM(UTC)
fairbank56
Groups: Expert
I agree with denman that it is probably an open heater element as that may give your exact symptoms of no heat, no timer advance in auto dry and timer advance but no shut off in timed dry however this is just a best guess without having the dryer model number. Without the number, we can't look at the wiring diagram or parts diagrams. There are many variations among models.
Eric
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Is the timer bad? (Dryer Repair)
by FatnSlo 5/1/2023 1:35:57 PM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Older Maytag top load “timer” (Washer Repair)
by CP1 6/4/2022 3:58:19 PM(UTC)
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
Whirlpool Ultimate Care timer does not stop (Washer Repair)
by dcbapp 8/10/2021 7:08:43 AM(UTC)
Volume on Timer (Oven Repair (including Ranges and Cooktops))
by Guest 6/21/2021 3:25:41 PM(UTC)
