Hello, My dryer has been squeaking like crazy recently so I did some reading and ended up replacing the rear drum bearing. Now that it's back together it seems to be rubbing on what the service manual calls the manifold pipe causing a scraping sound. It does it off and on. I've linked a picture of where it is hitting. http://i.imgur.com/gegKq04.jpgThe part seems to only attach at the top and does not offer much of a way to adjust its distance from the drum. Looking for advise on what other parts may need replacing or adjustments I should do. Thanks.
