Discuss
Kenmore He4T Tripping Breaker
 in
Dryer Repair
Got a call from my wife yesterday that the dryer had quit. My son put a small load in, pressed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore He4T Tripping Breaker
  #1 (permalink)
Old 08-05-2014, 06:05 AM
Junior Member
Delaneykm is on a distinguished road
Default Kenmore He4T Tripping Breaker
Model Number: 110.85866400   Brand: Kenmore   Age: 5 - 10 years
Got a call from my wife yesterday that the dryer had quit. My son put a small load in, pressed start and it immediately stopped. When I got home, it seemed like it was getting no juice, so I checked the breaker and discovered it was tripped. I reset it, went back to the unit, set it to Air Dry, press start and got the same result - an immediate shutdown casued by the breaker tripping. Unit is about 8.5 years old, run regularly, but not overly hard, lint screen is cleaned with each use (unless the teenager is involved), and pipe has good flow. Any thoughts would be greatly appreciated. Thanks.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-06-2014, 01:35 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sounds like you have a short in the unit.
First I would check the terminal strip in the unit to be sure it is OK.
Next the most likely source is a grounded element.
Unplug the unit and both wires at the heating element.
Measure the element.
It should be 8 to 12 ohms.
Then measure from each element connector to the heater case.
Both should be infinite ohms.
If not the element is grounded and should be replaced.
Could also be a wire in the unit is shorted to the frame.
__________________
  #3 (permalink)
Old 08-06-2014, 01:36 PM
Junior Member
Default
Thanks for the information and for the tech sheet. That tech sheet will be incredibly helpful.
Last night I unplugged it and checked the power connections. Everything seemed good, but there was some lint. Not much, but there was some. I made sure everything was in place, vacuumed out the area and reconnected everything. I pulled the top of the unit off to check it for lint or anything obvious, and it was clean. I just checked all connections and then put it back together. I figured maybe the vibration from the washer sitting next to it could have unseated something. Upon throwing the breaker, the unit started running. It did not trip again. I have no idea if what I did changed anything, but for the moment, it's running.
Again, thanks for the help. I have a sneaking suspicion that this will happen again.
  #4 (permalink)
Old 08-07-2014, 02:04 AM
Senior Expert
APP Volunteer
Default
Yes that is usually what happens.
Never let the unit know that you really really really need it because that is when it will decide to go belly up again.
But perhaps you have better luck than I do.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Series Tripping Breaker After New Heating Element Install derekb914 Dryer Repair 1 06-26-2014 03:56 AM
Tripping breaker Bjy151 Microwave Repair 0 01-15-2014 05:05 PM
Tripping Breaker umreth@charter.net Refrigerator & Freezer Repair 0 11-22-2011 08:34 AM
Tripping Breaker kharriso Dryer Repair 2 09-22-2010 11:20 AM
Kenmore oven will not heat up after tripping breaker cvette1 Oven Repair (including Ranges and Cooktops) 0 10-06-2009 07:59 AM
