Discuss
Another Timer Problem
 in
Dryer Repair
Hi all, Model: Maytag MDG3706AWW Replacement Timer Part #: AP4047639 Problem: Dryer does not turn off on certain settings. Timer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Another Timer Problem
  #1 (permalink)
Old 08-02-2014, 10:39 PM
Junior Member
noodlenoggan is on a distinguished road
Default Another Timer Problem
Model Number: MDG3706AWW   Brand: Maytag   Age: 5 - 10 years
Hi all,
Problem:
Timer works/turns on Timed setting but does not properly work on Auto settings. This is with a new timer from AppliancePros.com.
Tests:
Checked all continuity of the thermostats and all are fine.
Below are test results from the various settings using a multimeter:
Auto Dry Regular Setting...
More Dry - 120v
Normal Dry - 120v
Somewhere between Normal and Cool Down, a click is heard when the timer knob is moved forward - 0v
Cool Down - 120v
Auto Dry Wrinkle Control Setting...
More Dry - 0v
Normal Dry - 0v
Less Dry - 0v
Cool Down - 120v
Timed Dry Setting...
100minutes to Cool Down - 120v
Diagnosis...Received a bad new timer or something else is wrong?
Question for the Pros...
I'm told that the timer motor power lines should always receive 120v when it's engaged. As noted above, at certain points, there is no power going to the motor so it doesn't move which results in the dryer being constantly running. Was I given correct info?
How are the other two knobs (Signal On/Off and Temperature) affect the timer motor, if it's affected by them? Would one or both of those knob settings cause the timer motor to be turned off/on?
Thanks!
Related Models
Maytag MDG3706AWW DRYER- GAS
Maytag MDG3757AWW DRYER- GAS
Maytag MDG3758AWW DRYER- GAS
Maytag MDG4000AWQ DRYER- GAS
Maytag MDG4000AWW DRYER- GAS
Maytag MDG4000AXQ DRYER- GAS
Maytag MDG4000AXW DRYER- GAS
Maytag MDG4000BWQ DRYER- GAS
Maytag MDG4000BWW DRYER- GAS
Maytag MDG4057BWQ DRYER- GAS
Maytag MDG4057BWW DRYER- GAS
Frigidaire MDG436MBW0 Kel(v27) / 27 " Gas Dryer
Frigidaire MDG436RBD0 Frg(v2) / 27 " Gas Dryer
Frigidaire MDG436RBD1 Kel(v3) / Gas Dryer
Frigidaire MDG436RBD2 Gib(v11) / Gas Dryer
Frigidaire MDG436RBW0 Tap(v10) / 27 " Gas Dryer
Frigidaire MDG436RBW1 Kel(v4) / Gas Dryer
Frigidaire MDG436RBW2 Gib(v12) / Gas Dryer
Frigidaire MDG436RED0 Frg(v1) / Gas Dryer
Frigidaire MDG436RED1 Frg(v1) / Gas Dryer
Frigidaire MDG436REW0 Frg(v2) / Gas Dryer
Frigidaire MDG436REW1 Frg(v2) / Gas Dryer
Maytag MDG4658AWW DRYER- GAS
Maytag MDG4806AWW DRYER- GAS
Maytag MDG4916AWA DRYER- GAS
Maytag MDG4916AWW DRYER- GAS
Maytag MDG5000BWQ DRYER- GAS
Maytag MDG5000BWW DRYER- GAS
Maytag MDG508DAWK DRYER- GAS
Maytag MDG508DAWW DRYER- GAS
Maytag MDG50MNAWW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50MNVWQ COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50MNVWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PN1AL MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PN1AW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PN2VW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNTVQ MAYTAG LAUNDRY COMMERCIAL (DRYER GAS)
Maytag MDG50PNTVW MAYTAG LAUNDRY COMMERCIAL (DRYER GAS)
Maytag MDG50PNVWQ COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNVWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PDAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PDSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Frigidaire MDG546RED0 Frg(v1) / Gas Dryer
Frigidaire MDG546RED1 Frg(v1) / Gas Dryer
Frigidaire MDG546RES0 Frg(v2) / Gas Dryer
Frigidaire MDG546RES1 Frg(v2) / Gas Dryer
Frigidaire MDG546RES2 Frg(v0) / Dryer
Frigidaire MDG546RET0 Frg(v3) / Gas Dryer
Frigidaire MDG546REW0 Frg(v4) / Gas Dryer
Frigidaire MDG546REW1 Frg(v3) / Gas Dryer
Maytag MDG5500AWQ DRYER- GAS
Maytag MDG5500AWW DRYER- GAS
Maytag MDG5806AWK DRYER- GAS
Maytag MDG5806AWW DRYER- GAS
Maytag MDG5960BWW DRYER- GAS
Maytag MDG6000AWQ DRYER- GAS
Maytag MDG6000AWW DRYER- GAS
Maytag MDG6000AXW DRYER- GAS
Maytag MDG6000BWQ DRYER- GAS
Maytag MDG6000BWW DRYER- GAS
Maytag MDG6200AWQ DRYER- GAS
Maytag MDG6200AWW DRYER- GAS
Maytag MDG6400AWQ DRYER- GAS
Maytag MDG6400AWW DRYER- GAS
Maytag MDG6460AWW DRYER- GAS
Maytag MDG6657BWQ DRYER- GAS
Maytag MDG6657BWW DRYER- GAS
Maytag MDG6700AWM DRYER- GAS
Maytag MDG6700AWW DRYER- GAS
Maytag MDG6800AWQ DRYER- GAS
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
  #2 (permalink)
Old 08-03-2014, 05:08 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The timer motor only receives power all the time in timed dry mode. In auto dry, the cycling thermostat either provides power to the heater or the timer motor. During the first part of auto dry, the wet clothes absorb most of the heat in the drum and thus not enough heat gets to the blower where the operating thermostat is and it doesn't change position. As the clothes get dry, more heat gets to the operating thermostat which causes it to begin cycling between powering the timer motor and heater. At the end of auto dry, a set of timer contacts closes to provide power to the timer motor all the time regardless of operating thermostat position. Monitor the voltage at the orange wire on the timer to determine if the operating thermostat is cycling. Voltage should switch between 120 and 0. You may have gotten a bad timer but problem could also be the operating thermostat is failing or there is an airflow problem.
Eric
  #3 (permalink)
Old 08-03-2014, 10:26 AM
Junior Member
Default
Thanks Eric.
I'll do as suggested.
I did clear all airflow paths of any lint/debris so airflow should be fine.
  #4 (permalink)
Old 08-03-2014, 04:30 PM
Junior Member
Default
Quote:
Can you clarify how I should monitor the voltage at the orange wire?
Do I just connect the multimeter probes to the orange wire and ground while it's running and wait? From your explanation, since the cycling thermostat needs to be triggered, it appears I would have to wait and watch for any voltage changes as the dryer is working. If so, how long should I sit, watch and wait before I suspect something is wrong?
Thanks!
  #5 (permalink)
Old 08-03-2014, 08:58 PM
Junior Member
Default
More observations...
1) the orange wire to the motor has a Y that also goes to the Temperature knob. Not sure if that helps. Since it was easier to access the orange wire connector here, I connected a small alligator clip to it and to a green ground wire. The other ends went to the multimeter.
2) When there is power, 120v, to the motor power cables, the same is true to the orange wire, vice versa.
3) On Auto Dry Regular setting, it heats up ONCE until it goes to that click mark just before the cool down mode. At this point, power to the motor is 0v (it's actually 1.xx volts). Heat no longer goes on even if I stop the dryer and restart it from the beginning of the cycle. Unplug and plug in power cord, same results.
4) On the Auto Dry Wrinkle Control Setting, 120v is shown when I turn the knob when the dryer is not running. The moment I press the knob to turn on the dryer, voltage drops to 0v. As long as I'm not in the Cool Down area, voltage stays 0.
Methinks there's a sensor I missed somewhere. When I opened up the unit, I see what appears to be 2 sensors near the gas flame burner toward the front of the unit. These were the ones I tested and they have continuity. In the back is the heat airflow pathway into the dryer drum. I can't access this from the back of the machine. If there's another sensor back there, I'd have to remove the drum assembly to get to it. Otherwise, am I missing another somewhere else?
  #6 (permalink)
Old 08-04-2014, 06:52 AM
Expert
APP Volunteer
Default
There aren't any sensors in the back of the dryer. The only sensor that controls the timer motor is the operating thermostat located on the front of the blower housing. Does the timer advance on it's own during auto dry cycles? When the burner cycles off in auto dry, the timer should advance until burner lights again. Post a copy of your wiring diagram so I can compare it to the one I have for your model. May be different.
Eric
  #7 (permalink)
Old 08-04-2014, 09:17 AM
Junior Member
Default
In case the uploaded file is not legible, here's a link to my dropbox of a higher resolution version.
https://dl.dropboxusercontent.com/u/...804_090213.jpg
  #8 (permalink)
Old 08-04-2014, 01:30 PM
Expert
APP Volunteer
Default
Ok, that is the exact same one I have. You didn't answer the question as to whether the timer advances during auto dry. In the end stage of either auto cycle, timer contact 1A should close which applies 120vac continuously to the timer motor which should advance timer to the OFF position and turn the dryer off. If the timer does not get to the end stage of auto cycle, then either the operating thermostat is faulty or there is a heater/air flow problem preventing that thermostat from getting hot enough to cycle.
Eric
  #9 (permalink)
Old 08-04-2014, 06:29 PM
Junior Member
Default
Only the Timed and Auto Dry Regular settings advance by itself as noted in the first posting.
I'll open up the dryer again and recheck the continuity of the thermostats again.
Where else can I check for airflow problems? The outside vents gets plenty of exhaust flow. I've completely removed the plastic lint guard and washed it clear of any traces of lint. The airflow channel to the rear is cleared as well. The only section I haven't check is the heat flow channel into the drum from the backside.
  #10 (permalink)
Old 08-04-2014, 11:33 PM
Junior Member
Default
Opened the dryer and checked all three thermostats. Sure enough, the one at the exhaust end didn't have continuity. It was also the one where the orange wire was attached to. Let's hope this is the culprit.
Thanks Eric for all your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer Problem? Grump Dryer Repair 5 01-16-2013 04:33 AM
Timer problem... jameslaird Dishwasher Repair 1 05-19-2010 09:23 PM
Timer problem???? sacto Washer Repair 3 10-13-2009 05:32 PM
GE Top Loader--Problem with Timer Knob or Timer crmothorpe Washer Repair 3 04-27-2009 06:08 AM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
