Discuss
Maytag dryer start issues
 in
Dryer Repair
I have a SDE515DAYW dryer. When you select the beginning of any cycle the dryer will not start. The moisture
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer start issues
  #1 (permalink)
Old 08-01-2014, 06:22 PM
Junior Member
civilguy is on a distinguished road
Default Maytag dryer start issues
Model Number: SDE515DAYW   Brand: Maytag   Age: 5 - 10 years
I have a SDE515DAYW dryer. When you select the beginning of any cycle the dryer will not start. The moisture sensor led lights up and there is no noise. No hum, nothing.
If you manually move the timer to the very end of the cycle the dryer will start and run (after pushing the start button). I would deduce that this has to do with the heating elements as the end of the cycle does not draw on those parts. SO...
I read a lot online, and ended up trying a lot of troubleshooting.
1) The door switch and start switch/button are operational.
2) I have 240v and 120V coming into the unit (no breaker or house wiring issues).
3) The thermal fuse has continuity at room temp. I jumped it and no change in operation.
4) The high limit thermostat also has continuity at room temp. I jumped it and no change in operation.
5) The cycling thermostat has continuity at room temp. I jumped it and no change in operation.
6) Since the motor does start and run fine at the end of the cycle I don't think the motor is at fault.
ALL of this has lead me to believe the timer has died and I need to replace it. Everything I have read leads me to believe this is the least likely scenario though- and it's expensive.
My question is am I missing anything? What else could I check before buying a timer?
Thanks, Jeff
Related Models
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
Amana SDI22W-AG REF - SXS/I&W
  #2 (permalink)
Old 08-02-2014, 08:04 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Faulty timer. If bought from APP, the timer can be returned if it doesn't fix the problem. I don't see what else it could be though.
Whirlpool 33002676 Timer, Electronic Dry - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 08-05-2014, 11:00 AM
Junior Member
Default
I ordered a replacement timer Sunday night & it arrived this morning!! Super fast shipping. I installed it at lunch today. The dryer started up and heat kicked on. I still have to reassemble the dryer but I think we're safe from the laundromat for now!
Thanks for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag neptune dryer issues blueovalfever Dryer Repair 1 10-14-2013 07:35 PM
Old Maytag Stackable with Dryer issues shanahjc Dryer Repair 0 01-26-2013 07:11 PM
issues with maytag dryer cookieman Dryer Repair 1 03-30-2012 03:50 AM
Maytag Dryer issues jpstuhr Dryer Repair 1 05-28-2011 04:28 AM
Maytag Dryer circuit board issues josephtaylor Dryer Repair 1 12-30-2009 07:46 PM
