Discuss
won't stay started and won't heat
 in
Dryer Repair
The dryer won't run unless I keep the start button pushed in. However, even with the start button pushed in,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » won't stay started and won't heat
  #1 (permalink)
Old 07-30-2014, 04:08 PM
Junior Member
guybrarian is on a distinguished road
Default won't stay started and won't heat
Model Number: 11074992300   Brand: Kenmore   Age: More than 10 years
The dryer won't run unless I keep the start button pushed in. However, even with the start button pushed in, the dryer produces no heat. I replaced the thermal fuse, but it didn't solve either problem. What should I check next? Thank you.
Related Models
Kenmore 11074992300 GAS, DRYER
Kenmore 11074992301 RESIDENTIAL DRYER
Kenmore 11074994300 GAS, DRYER
Kenmore 11074994301 RESIDENTIAL DRYER
Kenmore 11074996300 GAS, DRYER
Kenmore 11074996301 RESIDENTIAL DRYER
Kenmore 11075062500 RESIDENTIAL DRYER
Kenmore 11075062501 DRYER
Kenmore 11075064500 RESIDENTIAL DRYER
Kenmore 11075066500 RESIDENTIAL DRYER
Kenmore 11075066501 DRYER
Kenmore 11075193 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075601 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075822400 RESIDENTIAL DRYER
Kenmore 11075922400 RESIDENTIAL DRYER
Kenmore 11075922401 RESIDENTIAL DRYER
Kenmore 11075924400 RESIDENTIAL DRYER
Kenmore 11075924401 RESIDENTIAL DRYER
Kenmore 11075926400 RESIDENTIAL DRYER
Kenmore 11075926401 RESIDENTIAL DRYER
Kenmore 11075942400 RESIDENTIAL DRYER
Kenmore 11075942401 RESIDENTIAL DRYER
Kenmore 11075944400 RESIDENTIAL DRYER
Kenmore 11075944401 RESIDENTIAL DRYER
Kenmore 11075946400 RESIDENTIAL DRYER
Kenmore 11075946401 RESIDENTIAL DRYER
Kenmore 11075962400 RESIDENTIAL DRYER
Kenmore 11075962401 RESIDENTIAL DRYER
Kenmore 11075964400 RESIDENTIAL DRYER
Kenmore 11075964401 RESIDENTIAL DRYER
Kenmore 11075966400 RESIDENTIAL DRYER
Kenmore 11075966401 RESIDENTIAL DRYER
Kenmore 11076002010 GAS DRYER
Kenmore 11076002011 GAS DRYER
Kenmore 11076051690 COMMERCIAL GAS DRYER
Kenmore 11076051691 COMMERCIAL GAS DRYER
Kenmore 11076058690 COMMERCIAL GAS DRYER
Kenmore 11076058691 COMMERCIAL GAS DRYER
Kenmore 11076065 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11076071690 COMMERICAL GAS DRYER
Kenmore 11076071691 COMMERCIAL GAS DRYER
Kenmore 11076112500 DRYER
Kenmore 11076112501 RESIDENTIAL DRYER
Kenmore 11076152500 RESIDENTIAL DRYER
Kenmore 11076401100 KENMORE ELECTRIC DRYER
Kenmore 11076401400 KENMORE ELECTRIC DRYER
Kenmore 11076401600 KENMORE ELECTRIC DRYER
Kenmore 11076402100 KENMORE ELECTRIC DRYER
Kenmore 11076402110 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402400 KENMORE ELECTRIC DRYER
Kenmore 11076402410 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402600 KENMORE ELECTRIC DRYER
Kenmore 11076402610 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076403100 KENMORE ELECTRIC DRYER
Kenmore 11076403400 KENMORE ELECTRIC DRYER
Kenmore 11076403600 KENMORE ELECTRIC DRYER
Kenmore 11076404100 KENMORE ELECTRIC DRYER
Kenmore 11076404110 SEARS ELECTRIC DRYER
Kenmore 11076405100 KENMORE ELECTRIC DRYER
Kenmore 11076405400 KENMORE ELECTRIC DRYER
Kenmore 11076405600 KENMORE ELECTRIC DRYER
Kenmore 11076406100 KENMORE ELECTRIC DRYER
Kenmore 11076406110 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076406400 KENMORE ELECTRIC DRYER
Kenmore 11076406410 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076406600 KENMORE ELECTRIC DRYER
Kenmore 11076406610 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076407100 KENMORE ELECTRIC DRYER
Kenmore 11076407400 KENMORE ELECTRIC DRYER
Kenmore 11076407600 KENMORE ELECTRIC DRYER
Kenmore 11076408100 KENMORE ELECTRIC DRYER
Kenmore 11076408110 SEARS ELECTRIC DRYER
Kenmore 11076408120 ELECTRIC DRYER
Kenmore 11076408130 ELECTRIC DRYER
Kenmore 11076408140 ELECTRIC DRYER
Kenmore 11076408150 ELECTRIC DRYER
Kenmore 11076408160 ELECTRIC DRYER
Kenmore 11076408220 ELECTRIC DRYER
Kenmore 11076408230 ELECTRIC DRYER
Kenmore 11076408240 ELECTRIC DRYER
Kenmore 11076408250 ELECTRIC DRYER
Kenmore 11076408400 KENMORE ELECTRIC DRYER
Kenmore 11076408410 SEARS ELECTRIC DRYER
Kenmore 11076408420 ELECTRIC DRYER
Kenmore 11076408430 ELECTRIC DRYER
Kenmore 11076408440 ELECTRIC DRYER
Kenmore 11076408450 ELECTRIC DRYER
Kenmore 11076408600 KENMORE ELECTRIC DRYER
Kenmore 11076408610 SEARS ELECTRIC DRYER
Kenmore 11076408620 ELECTRIC DRYER
Kenmore 11076408630 ELECTRIC DRYER
Kenmore 11076408640 ELECTRIC DRYER
Kenmore 11076408650 ELECTRIC DRYER
Kenmore 11076408660 ELECTRIC DRYER
Kenmore 11076408800 KENMORE ELECTRIC DRYER
Kenmore 11076408810 SEARS ELECTRIC DRYER
Kenmore 11076408820 ELECTRIC DRYER
Kenmore 11076408830 ELECTRIC DRYER
Kenmore 11076408840 ELECTRIC DRYER
Kenmore 11076408850 ELECTRIC DRYER
Kenmore 11076408860 ELECTRIC DRYER
Kenmore 11076409100 ELECTRIC DRYER
Kenmore 11076409110 ELECTRIC DRYER
Kenmore 11076409120 ELECTRIC DRYER
Kenmore 11076409130 ELECTRIC DRYER
Kenmore 11076409140 ELECTRIC DRYER
Kenmore 11076409150 ELECTRIC DRYER
Kenmore 11076409210 ELECTRIC DRYER
Kenmore 11076409220 ELECTRIC DRYER
Kenmore 11076409230 ELECTRIC DRYER
Kenmore 11076409240 ELECTRIC DRYER
Kenmore 11076409410 ELECTRIC DRYER
Kenmore 11076409420 ELECTRIC DRYER
Kenmore 11076409430 ELECTRIC DRYER
Kenmore 11076409440 ELECTRIC DRYER
Kenmore 11076409610 ELECTRIC DRYER
Kenmore 11076409620 ELECTRIC DRYER
Kenmore 11076409630 ELECTRIC DRYER
Kenmore 11076409640 ELECTRIC DRYER
Kenmore 11076409650 ELECTRIC DRYER
  #2 (permalink)
Old 07-30-2014, 04:24 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
First, try swapping the two relays (motor and heat) behind the control panel. If motor still will not stay running when you release the start button,it's likely a faulty control board as it's not likely that both relays are bad.
Whirlpool W10116565 Electronic Control Board - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 07-30-2014, 04:26 PM
Junior Member
Default
Thank you, Eric. Can I test the motor relay and heat relay with a multimeter? Or is it better to replace them outright?
  #4 (permalink)
Old 07-30-2014, 04:48 PM
Expert
APP Volunteer
Default
I didn't mean for you to replace them, just swap them. They are both the same. Note the wiring color code, disconnect the wiring and swap one for the other.
Eric
  #5 (permalink)
Old 07-30-2014, 06:29 PM
Junior Member
Default
I swapped the relays. Same problems -- dryer won't stay on and won't heat. I had replaced the motor relay about a year ago. I was hoping a bad heat relay was causing the problem this time, but I guess not.
The dryer probably isn't worth a $170 control board. Is there anything else I can try? Thank you.
  #6 (permalink)
Old 07-31-2014, 07:04 AM
Expert
APP Volunteer
Default
Closely inspect the even heat control board. Sometimes when they fail, it is obvious as there is a burnt component and darkening/browning on a portion of the board. If it looks good, it could still be bad but there is the remote chance that both relays are bad. Unplug dryer and disconnect the two pink/black wires from the motor relay and check resistance across those terminals on the relay. This is the relay coil and should read around 2-3 k-ohms. If good, plug dryer back in and check the DC voltage across the two pink/black wires when you press the start button for normal operation. Voltage should be 48VDC. If you don't get 48VDC then the board is bad. Same tests for the heat relay, wire colors for relay coil are red/white.
Eric
  #7 (permalink)
Old 07-31-2014, 07:06 AM
Junior Member
Default
I'll give it a shot. Thank you, Eric. You've been extremely helpful.
  #8 (permalink)
Old 07-31-2014, 06:31 PM
Junior Member
Default
The R2 resister on the electronic control assembly looks burnt. I tested the motor relay anyway. I got 3k ohms between the pink/black terminals.
I got no reading when I tested the pink/black wires with the start button pushed in. However, I'm not sure I was testing the wires correctly. I'm a moron with a multimeter. To test VDC, do I put the positive probe on the pink/black wire terminal and the negative probe on the relay terminal?
  #9 (permalink)
Old 08-01-2014, 05:26 AM
Expert
APP Volunteer
Default
That's the common failure part, R2, on these boards. Your not alone. Every time we see an "Even Heat" dryer, we pretty much know it's the board or one of the relays. High failure items on these dryers. You should check the DC voltage across the wires.
Eric
  #10 (permalink)
Old 08-05-2014, 05:23 PM
Junior Member
Default
Yep, it was the control board. I replaced it, and now the dryer stays on and heats. Thank you for the advice, Eric. You saved me hundreds of dollars.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
will not stay started Doug Casey Dryer Repair 3 07-10-2012 01:23 PM
Dryer Won't Stay Started gbroberts Dryer Repair 1 03-31-2011 04:18 AM
dryer will not stay started lakeview Dryer Repair 0 06-02-2009 06:05 AM
Dryer wont fire up or stay started. BrianE Dryer Repair 0 05-26-2009 02:48 PM
dryer won't stay started 8man Dryer Repair 2 03-28-2009 05:16 AM
