Discuss
Kenmore Dryer won't spin
 in
Dryer Repair
Hi there! My electric dryer will not spin. I could hear the motor humming trying to start, so I gave
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer won't spin
  #1 (permalink)
Old 07-29-2014, 06:59 AM
Junior Member
Connito is on a distinguished road
Default Kenmore Dryer won't spin
Model Number: 417.82142101   Brand: Kenmore   Age: 5 - 10 years
Hi there!
My electric dryer will not spin. I could hear the motor humming trying to start, so I gave it a push with my hand and it started spinning. Once it starts its all fine. Does the motor have brushes? It seems like the problem might be worn brushes? Or some kind of relay? Please help!
Thanks in advance,
Connito
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 07-29-2014, 08:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
No.
It also does not have a relay.
Turn the drum in the correct direction.
Just to see if there is too much drag on it and that is preventing it from running.
You may want to try this on a couple other units to get a feel for it.
If set to a heating cycle does it produce heat when the drum is not turning?
If yes then it could be a problem with the centrifugal switches on the motor always being activated.
There are two switches on the motor.n They activate when the motor gets close to operating speed.
One of them switches on the heater.
The other switches out the start relay which would cause the motor to overheat if left in circuit.
So if the switches are activated when the motor is at rest. You get heat and there is no start winding so the motor will not start.
Check /clean the motor.
Check the wires at the motor.
Note that usually your problem requires replacing the motor but it is worth checking the above.
Part number: AP2107144
Click on the picture for more info about the part.
It may not be worth fixing unless it is in good shape.
I would check all moving parts, seals etc. in it before ordering a motor soyou will have an idea what a basic overhaul of the unit will cost.
__________________
  #3 (permalink)
Old 07-29-2014, 09:37 AM
Junior Member
Default
Thank you so much for your quick and thorough reply!!
There is no resistance when I turn the drum and when give it a push it starts to spin with load of wet clothes in it without a problem. It seems that the motor is okay, it's just has a hard time starting. Perhaps that means that I need a new one? I am not sure what do you mean by checking the motor. What should I check? I suppose I will take the dryer apart and clean the motor and perhaps then I will see something obvious.
The unit doesn't start at all, or doesn't turn on so to speak, unless the drum is turning.
Thanks again!
Best,
Connito
  #4 (permalink)
Old 07-29-2014, 11:43 AM
Senior Expert
APP Volunteer
Default
Yes that is normally where this type of problem sends up.
Make sure it is clean and not clogged solid with lint.
Check the wires that connect to it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer/Dryer combo won't drain or spin uttdawg Washer Repair 5 12-30-2014 09:01 AM
Kenmore 98702 Stacked Washer/Dryer won't spin flashpipe Washer Repair 1 04-22-2011 12:39 PM
Kenmore Ultra Fabric Care Dryer (gas) won't spin tdmbulk Dryer Repair 3 07-01-2010 02:23 PM
dryer will heat but not spin- kenmore 70 series model abengoa Dryer Repair 1 09-14-2009 08:54 PM
kenmore dryer woulnt spin davdmad Dryer Repair 4 04-19-2008 05:57 PM
