Discuss
Gas dryer not heating
 in
Dryer Repair
The tub spins and everything else seems to work fine. The appliance seems to be in good condition and is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer not heating
  #1 (permalink)
Old 02-16-2008, 08:34 PM
Penthor Penthor is offline
Junior Member
Penthor is on a distinguished road
Default Gas dryer not heating
Model Number: LGR8858EQ3   Brand: Whirlpool   Age: 5 - 10 years
The tub spins and everything else seems to work fine. The appliance seems to be in good condition and is installed indoors. I found a similar post here If those same instructions apply to my particular model I'll proceed with the continuity testing in the morning. Thanks. And great forums!
Penthor
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-17-2008, 08:32 AM
Junior Member
Default
Looking at the machine I can't tell the best route of entry. Is it best (possible?) to go in through the top, front, or back? Thanks.
  #3 (permalink)
Old 02-17-2008, 09:29 AM
Junior Member
Default
FYI
The back is the best route to take. My thermal fuse was blown. It's eerie how just talking to myself on this forum has helped me solve the problem.
  #4 (permalink)
Old 02-17-2008, 09:56 AM
Junior Member
Default
Out of curiosity is there a way to test the cycling thermostat with an Ohm meter? It has 4 leads. The circuit between the 2 outside leads is closed; between the 2 inside it is open.
Reply
« dryer | poor heat »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer not heating jakelexie Dryer Repair 1 01-25-2008 04:51 PM
Dryer not heating VBN Dryer Repair 1 08-20-2007 11:16 AM
Dryer Not Heating Jorja Dryer Repair 1 08-16-2007 11:14 AM
Dryer not heating Jackie Dryer Repair 4 07-27-2007 11:05 AM
dryer not heating vonryansexp Dryer Repair 0 07-24-2007 12:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
