Fixitmyself614
#1 Posted : Friday, July 25, 2014 5:28:17 PM(UTC)
Fixitmyself614
Dryer wouldn't start replaced thermal fuse started dryer ran a load dryer smells like it was over heating then cut off and won't start now any suggestions
#2 Posted : Saturday, July 26, 2014 3:19:24 AM(UTC)
Parts for Roper REX4634KQ1 Dryer - AppliancePartsPros.com
When you replaced the thermal fuse did you check/clean the vent system.
This is the most common cause of the fuse blowing.
Also be sure that the vents on the outside of the house are opening.
sea157
#3 Posted : Saturday, July 26, 2014 3:21:23 AM(UTC)
sea157
Check your duct work to make sure it is not full of lint.
Make sure you are getting a good strong flow of air coming out of your dryer vent.
Fixitmyself614
#4 Posted : Tuesday, July 29, 2014 2:38:42 AM(UTC)
Fixitmyself614
I Checked my Ducks made sure all vents were clean changed thermal fuse again dried a load of clothes then dryer stop again! What else could this be ?
#5 Posted : Tuesday, July 29, 2014 3:14:27 AM(UTC)
See the attachment for your wiring diagram.
Unplug the unit and both wires at the heater.
Measure the heater should be 8 to 12 ohms.
Then check from each side of the element to the heater's case.
Both should be infinite ohms.
If not the element is grounded and could run hot.
Did the unit have good air flow?
Check that the blower wheel is properly connected to the motor armature.
Sometimes they strip out. Will spin some but not enough.
Check that the blower wheel is clean.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
REX4634.pdf (210kb) downloaded 0 time(s).
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
