Discuss
Dryer only heats on timed setting
 in
Dryer Repair
Our dryer only heats on the timed settings. If I use the intellidry setting it will not ignite. Where would
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer only heats on timed setting
  #1 (permalink)
Old 07-23-2014, 01:08 AM
Junior Member
Trebortrebor235 is on a distinguished road
Default Dryer only heats on timed setting
Model Number: Sdg4606aww   Brand: Maytag   Age: 5 - 10 years
Our dryer only heats on the timed settings. If I use the intellidry setting it will not ignite. Where would I go to find the problem. Is it in the panel or a separate sensor that is used on that cycle?
Related Models
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
Amana SDI22W-AG REF - SXS/I&W
Amana SDI22W-C REF - SXS/I&W
Amana SDI22W-L REF - SXS/I&W
Amana SDI25A REF - SXS/I&W
Amana SDI25A-A REF - SXS/I&W
Amana SDI25A-AG REF - SXS/I&W
  #2 (permalink)
Old 07-23-2014, 07:16 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Faulty timer.
Whirlpool 33002676 Timer, Electronic Dry - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 07-23-2014, 08:37 PM
Junior Member
Default
Eric
I will give that a try. Thank you. Will use your web site to order the part
Bob
  #4 (permalink)
Old 07-26-2014, 09:09 PM
Junior Member
Default
I found that it will ignite but only hear for about 2 min then the flame stops but dryer stays running with no heat. Could it be a sensor?
  #5 (permalink)
Old 07-27-2014, 05:37 AM
Expert
APP Volunteer
Default
In both timed dry and auto dry? Did you replace the timer?
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer heats and works on timed settings but will only heat intermitantly on auto stick86 Dryer Repair 1 04-14-2013 11:23 AM
dryer only heats on moisture sensing cycle more dry setting jwilcoxen Dryer Repair 0 02-15-2012 09:51 PM
Bosch dryer WTA 3510 heats up only in the "Timed Cycles". deberhard Dryer Repair 0 07-11-2011 08:52 PM
Dryer no heat, Timer no advance except timed dry, will not shut off on timed dry RichDryer Dryer Repair 2 03-15-2010 07:34 PM
GE Dryer wil not heat up on anything but timed setting. todv Dryer Repair 0 11-16-2008 06:20 PM
