In the past few months, every so often, the dryer would start a few seconds after the button was pushed. Last night the dryer stopped after running for a few minutes. I turned the power off and back on and still it would not start. When I went to move the dryer to unplug it from the wall, it started to dry again. I turned it off again and then tried to turn it on and it wouldn't work until I moved the dryer.
Does this sound like a relay issue or a motor issue?
